  3. Results Browser: "Append" new "psf's"
  • Views 1500
Ionutz
Ionutz over 9 years ago
 Lets say I have an AdeXL session and just ran some sims stored as "Interactive.0". From those I pick three corners and RighClick to send them to Results Browser.
Now I re-run the tests (with some minor changes) and have a new "Interactive.1". I RightClick on the new three corners and send them to the Results Browser.
 The Results Browser "closes" the "Interactive.0" psf's and replaces with the "Interactive.1" psf's.
 Is there a way to tell it to just append the new psf's so I can manipulate all siz psf's together without having to open manually one by one?
 When trying to plot just a signal, U can use the "Append" options and works fine... is there a simillar feature for the psfs? :(
 Thank U,
Ionut
    Hi Ionut,
    envSetVal("adexl.plotting" "onlyLoadUserSelectionInResultsBrowser" 'boolean nil)
    will do this. We've been having a discussion about the best way of making this show up in the user interface via CCR 1676093. The current favourite is to have an option on the print/plotting options form in ADE XL to determine whether it appends or replaces the open databases when using the Results Browser menu. However, for now, the env var above is the way to do this.
  • Ionutz
    Thank U very much... that seems to work :)
    Best regards,
    Ionut
