  3. I installed a new GF55lpx PDK, and I when I run PVS-QRC...
  • Views 15309
I installed a new GF55lpx PDK, and I when I run PVS-QRC, I get incorrect models name in Spectre netlist and in av_extracted view
smartind
smartind over 9 years ago
I'm setting up a new PDK and I have PVS-LVS working.
When I generate a QRC(13.2) exrtacted view,  I get parasitic- capacitor cells "pcapacitor"
and parasitic-resistor cells ="presistor" in the "av_extracted" view in the Library Manager.
Which appears OK,  because "pcapacitor" and "presistor" are the default parasitic components
in the QRC "Setup" menu.  And "pcapacitor" and "presistor" are in the "analogLib".
But when I do a "q" on any parasitic cap in the "av_extracted" view,  it shows the "Model" name is "cmodel".
And when I do a "q" on any parasitic metal-1 resistor,  it shows the "Model name" is "M1".
And when I do "q" on any poly resistors it shows the "Model name" is "PC1".
So these model names end up in the Spectre netlist "input.scs",  which is used to run the Spectre simulation.
And the Spectre sim errors out with "SFE-23" error  ="instance is referencing an undefined model or subcircuit",
for each parasitic R and C.
Clearly the parasitic Rs and Cs are not mapping to Spectre simulate-able primitive/models.
I searched through the QRC Extraction-13.2 manual and I don't find much information about how to map
"pcapacitor" and "presistor" to simulate-able primitives like "res" and "cap" from the "analogLib".
It appears there are two ways to fix this problem. If there is a standard mapping file that maps "cmodel" to"cap",
and maps "M1" to "res" and "PC1"  to "res",  this would probably fix the problem.
Or, can I change something in the QRC "Setup" menu to do this component mapping ?  can I change "presistor" to "res" ?
and pcapacitor = "cap" ? or change the "Prop Id" field from "r" to "res" and "c" to "cap" ?
But I don't find a good explanation for the "Prop ID" field in the QRC manual.
Question, is this a mapping file problem, or lack of mapping file problem ?  , or a QRC "Setup" menu problem ?
And if it is a missing mapping file, what is the format of this file  ?  and how do you point to it ?
Is this a file that should have been supplied inthe QRC rules director ?
That's my question today.
  thanks,     -steve
    Steve,
    Most likely this is because you have the settings on the Netlisting tab of QRC incorrectly set. If you have them set to "Include Model" for the two parasitic entries, it will end up adding a model parameter on each parasitic in the extracted view (which will then get netlisted by the spectre netlister, for example) which gives an indication of which type of parasitic it is. Most of the time, you probably don't want that and so should have it set as follows:
