  3. netlist generated by ADEXL doesn't match with ADEL
  • Views 3733
nicola91it
nicola91it over 9 years ago
I am currently using Cadence IC6.1.6.500.4. performing corner simulation. All the corners have been good until I encountered a corner I didn't like, so I checked possible solutions with ADEL. The problem is that the result doesn't match with the one obtained with ADEXL.
Obviously. I double checked all the settings, all the variables, the library path, the references to the schematic and they are exactly the same. So, I created the netlist using both ADEL and ADEXL and I compared them with a text comparator. Here attached there is the picture that shows the only difference encountered (left is ADEL netlist and right is the ADEXL). As can be seen, in ADEXL netlist the part I52.I74:2 is missing (in my case I52 and I74 are both instances, but I don't know what :2 means).
Following this way, I tried to look at a transient signal in the part that is missing in the same corner, and ADEXL correctly plot it without any problems.
I also tried to verify other corners, but in many other cases (I can't compare all the corners) the results from ADEXL perfectly match with the results of ADEL. even if the netlist difference is still present.
I really don't know what's happening: furthermore, I don't know why when I open the ADEXL test I can't run a simulation with that interface (the picture is attached).
I would be graceful to receive some help. Thank you and regards
  • Marc Heise
    Marc Heise over 9 years ago
    Hi Nicola,
    the difference in your netlist is the save statement for the current in the terminal "2" of the device "I74". The current is not saved to the disk and can't be viewed after the simulation. The simulation itself should not be influenced by that.
    It's not clear for me what exactly is not matching between the ADEXL and the ADE simulation. Do you get different results for some measurements?
    The last picture you attached is showing t our so called "Test Editor". It is basically the ADE interface without the run buttons. It's purpose is to make it easy to setup
    tests for ADEXL using the old trusted environment. After you make your changes there, you close it and run the test in ADEXL.
    The easiest way to debug a troublesome corner is to use the "Troubleshoot Corner"mode. First you run your Corners in ADEXL, when looking at the results display you can right click in the results and select "Troubleshoot Corner" from the popup. This will transfer the corner setup to an ADE interface, where you can dig deeper into that corner. Please see the documentation for that one.
    Hope that cleared up some things.
    Marc
  • nicola91it
    Hi Marc,
    thank you for your reply. Actually I didn't know the troubleshoot function, it looks very useful and I will use it. My problem was that I set up manually the same conditions encountered in the corner that I didn't like in ADE, I simulated with ADEL and the result didn't match. So I decided to download again the test editor with the same ADEL I was using for the simulations, and then the result matched. Actually I don't really know the reason, because I thought that once you set the global variables in ADEXL, it should't make any difference the value of the so called Design Variables, so this is still not clear.
    I know that to use ADEL to verify a corner is not a good procedure, I think one should use directly the test editor, but in my case as you can see from the previous picture, I don't have the "run" option in the interface: is it only my problem or it depends on the Cadence version? Thank you and regards
    Nicola
    Not entirely sure you want to run this way (you can, but not sure why you want to do it), but the default changed in an IC616 ISR. You can do:
    envSetVal("adexl.testEditor" "showAllMenus" 'boolean t)
    This will add the run button in the ADE XL test editor; it's there anyway in later hot fixes. You can also use the Right Mouse->Debug environment over a failing corner to re-run in an ADE-L like environment the failing point.
  • nicola91it
    thank you for your reply and for your help. Yeah, the way you indicate it's much better than modifying the test environment for every specific corner, so I'll follow your advice. Thank you and regards,
    Nicola
