  3. Error SFE-23 (undefined model or subcircuit modp and modn...
  • Subscribers 133
  • Views 36039
Error SFE-23 (undefined model or subcircuit modp and modn) and Error (SFE-874)
DomPaw
DomPaw over 9 years ago
Dear Cadence Community
I've got some serious problems which i need to solve as soon as possible. I'm a new Cadence user, i've tried to launch ADE and unfortunately i can't make any simulations because of those problems below.
Error found by spectre in `uklad', during circuit read-in.
ERROR (SFE-23): "input.scs" 13: The instance `MP10' is referencing an undefined model or subcircuit, `modp'. Either include the file containing the definition of `modp', or define `modp' before running the simulation.
ERROR (SFE-23): "input.scs" 29: The instance `MN11' is referencing an undefined model or subcircuit, `modn'. Either include the file containing the definition of `modn', or define `modn' before running the simulation.
ERROR (SFE-23): "input.scs" 48: The instance `R0' is referencing an undefined model or subcircuit, `rpoly1'. Either include the file containing the definition of `rpoly1', or define `rpoly1' before running the simulation.
When I tried to fix this problem this way   Setup-->Model Library-->(added cds.lib) i've got another problem:
ERROR (SFE-874):  14: Unexpected string value "#--------------------------------------------------------------------------------".
ERROR (SFE-874): " 32: Unexpected end of line.
ERROR (SFE-874): "33: Unexpected end of line.
ERROR (SFE-874):34: Unexpected end of line.
ERROR (SFE-874):  35: Unexpected end of line.
ERROR (SFE-874):36: Unexpected end of line.
ERROR (SFE-874): 37: Unexpected end of line.
ERROR (SFE-874): 39: Unexpected end of line.
ERROR (SFE-874): 40: Unexpected end of line.
ERROR (SFE-874): "41: Unexpected end of line.
ERROR (SFE-874):  42: Unexpected end of line.
ERROR (SFE-874): "43: Unexpected end of line.
ERROR (SFE-874):  44: Unexpected end of line.
ERROR (SFE-874):  45: Unexpected end of line.
ERROR (SFE-874):  46: Unexpected end of line.
ERROR (SFE-874): " 47: Unexpected end of line.
ERROR (SFE-874):  48: Unexpected end of line.
ERROR (SFE-874):  49: Unexpected end of line.
ERROR (SFE-874): " 50: Unexpected end of line.
ERROR (SFE-874): 51: Unexpected end of line.
ERROR (SFE-874):  52: Unexpected end of line.
ERROR (SFE-874):  53: Unexpected end of line.
ERROR (SFE-874): " 54: Unexpected end of line.
ERROR (SFE-874): 55: Unexpected end of line.
ERROR (SFE-874): 56: Unexpected end of line.
ERROR (SFE-874):  57: Unexpected end of line.
ERROR (SFE-874): 58: Unexpected end of line.
ERROR (SFE-874): 59: Unexpected end of line.
ERROR (SFE-874): 60:Unexpected end of line. Expected equals sign, numeric value or string value.
(Deleted my path, just showing errors)
I tried another way, adding file input.scs in the model library then the fatal error came out :
FATAL (SFE-879): Recursive file include or library call: `/.../spectre/schematic/netlist/input.scs'.
Can anyone help me with this issue please?
Dominik
    Hi Dominik,
    Oh dear - you really do appear to be trying random things which will stand no chance of working.
    Often design kits will set up the model path automatically to ensure the models are defined - if they don't, there's presumably some documentation with the design kit to tell you where the model files are. These are the transistor models (subckts, model statements) that need to be included so that Spectre knows the meaning of the primitive devices (modp and modn in your case). These are probably defined somewhere in a file with a ".scs" suffix (although it is possible that they're defined in SPICE syntax so they could be described differently). Without knowing what technology or design kit you're using, I doubt anyone could guess what the file is likely to be called (unless they happen to recognise the "modn" and "modp" model names).
    Including the cds.lib makes no sense; that's the definition of Virtuoso libraries (containing symbols, schematics, CDF, layouts and so on) for the Virtuoso tools to use. Virtuoso must be seeing that otherwise you couldn't draw your schematics. It's certainly not a spectre model file, hence the syntax errors.
    Including the input.scs similarly makes no sense - all the model libraries form does is specify a bunch of files to include in the input.scs that it is generating, so putting a reference to itself makes no sense (hence the error about it being recursive).
  • DomPaw
    Hi Andrew
    Thanks for the quick answer, I presume that the only thing I need to do is to add the right file with models ?
    Hit-KIt: ams_4.10 Tech:c35b4
    Dominik
    Hi Dominik,
    I think (I haven't used an AMS hit kit for a few years) that you have to include <hitkitroot>/spectre/h35/cmos35.scs (it might be h35, or s35, or c35), and you'd need to specify an appropriate section from the models. However, the section names you should use may depend on the technology, version and so on - and you probably also want other model files included.
    I strongly suggest you contact AMS to ask them if you don't have the documentation, since I would hate for you to be including the wrong files and getting incorrect simulation results.
  • DomPaw
    I'll try to do so, Thanks for help and advice.
    Dominik
