  3. How do I override irunArgs being set by the ADE state when...
  • Views 16156
How do I override irunArgs being set by the ADE state when using runams?
feory
feory over 9 years ago
I am using a command line AMS simulation flow with the runams command and my own script that builds many, but not all, of the irunArgs I need. The remaining irunArgs come from the ADE state. I have lots of different testcases that all use the same ADE state. One of the arguments I would like to change on an individual testcase basis is the number of threads for multithreading. I am able to use -irunopts 'spectre_args +mt=10' (for example), and I see this being set in my irun.log file. The problem is that the irunArgs that come from the ADE state are set after this, so whatever multithreading option I have saved in the ADE state overrides the one I previously set with -irunopts from my script.
Is there a way to override or suppress some of these irunArgs that are set by the ADE state file? Alternatively, is there a way to use runams without a state file, and just specify everything from an external irunArgs file?
    Hi Frank,
    I don't think you can suppress bits of the ADE state, but you can just run runams without the -state argument. Just look at "runams -help" for details on how to use this - there are numerous options to supply extra bits of information without needing to use an ADE state.
  • feory
    Thanks Andrew, I'll give that a try after the holidays. It would be nice to just eliminate the ADE state altogether.
  • Adam Daniels
    Adam Daniels over 8 years ago
    An indirectly related question. The default irunArgs file that is created, whether I use a state or not, contains a -timescale statement that I am trying to set to another value in my own arguments file. using -f, or -irunopts to bring in my own arguments doesn't override the default irunArgs file inclusion, as I would expect. Due to this I get an error that -timescale is set twice.
    Is there some way of switching off the default irunArgs file, I can find nothing in the documentation.
