  3. Enhancing the status toolbar.
  • Views 14981
GirishRK
GirishRK over 9 years ago
I'd like to add functionality to the status toolbar on Virtuoso Layout-XL, for instance to indicate whether gravity is turned on or turned off (like the P/F indicator for Partial or Full select). Is there a way to add text indicators to the status toolbar?
    No, this isn't possible currently. You'd have to add a create and add a new toolbar instead. You could then use envRegSetTrigger("layout" 'yourFunction) to trigger when the environment for layout changed, and use this to get the current value for gravity settings and update your toolbar that way.
