  3. Virtuoso Schematic - Enviroment - "move/copy" Snap mode
  • Views 3335
Ionutz
Ionutz over 9 years ago
 I am using Virtuoso v12 and trying to figure out the environment that controls the "Snap Mode" when copy/move a symbol.
Where can I find the list of enviroments that I can set in a local cdsenv and set for instance the "Snap Mode" to be "anyAngle"? :(
On the same topic: are there similar variables to turn off the "Navigator" and "Property Editor" Assistants to come up by default when opening a new schematic? :(
 Thank U,
Ionut
  • Ionutz
    I think I found the answer to the first question:
    envSetVal("graphic" "segSnapMode" 'string "anyAngle")
    For the second question (about assistants), use Window->Workspaces->Classic (this probably is the one you want - make sure the assistants are removed) and then do Window->Workspaces->Set Default. The settings are saved into one of the .cadence directories.
  • Ionutz
    Thank U for the info... that works :)
    Ionut
