  3. "Report Parasitics" cannot be Clicked
  • Views 2433
canbaltaci
canbaltaci over 9 years ago
I am using the version IC6.1.6-64b.500.11 and I have a problem regarding reporting the parasitics.
I run Calibre QRC and create av_extracted view. The on the schematic of the corresponding cell, I open the Parasitics tab (First I do: Launch/Plugins/Parasitics). By using Parasitics tab, I select the corresponding av_extracted view. I can show and hide parasitics very well on the schematic without a problem. However, "Report Parasitics" tab is not clickable. Thus, I am not able to report the node-to-node parasitics after performing a coupled parasitic extraction. Is there a solution for this issue? Why is "Report Parasitics" unclickable?
Note: I have a parametric av_extracted view for nominal and Cmax.
Thank you very much in advance.
Best regards,
Can
    This is a bug that was just in that subversion and is described in this support article. IC616 ISR12 was fixed.
    There's a workaround described in the article which was to use the following steps:
    1. Launch –> Plugins –> Parasitics
    2. Complete the parasitics setup using menu Parasitics –> Setup...
    3. Launch –> Plugins –> Parasitics (this will remove Parasitics menu)
    4. Launch –> Plugins –> Parasitics (to add Parasitics menu again)
    The Parasitics menu re-added after doing steps 3 and 4 above will have Report Parasitics menu item enabled.
  • canbaltaci
    Thank you very much, now it works.
    Best regards,
    Can
