  3. power drop not seen in av_extracted simulation
  • Views 14464
primemath
primemath over 9 years ago
I did simulation with ultrasim on av_extracted netlist for my design. but i see that each point in the Power supply there is an ideal voltage present (no droop in the voltage)
I am facing an issue in analyzing the Voltage droop on power nets in my design. I did the av_extraction for my design and ran it with ultraism with analog mode settings.
usim_opt sim_mode=ms analog=2 speed=5 method=gear2
usim_opt sim_mode=a subckt=chipid_bond_pad_aligned speed=5
Now I am seeing that at each of the point in the Power mesh its an ideal voltage coming (which is not real). It should show some drop. In av_extracted view I am seeing RC’s (parasitics) present on the power network.
But why its not visible in the simulation.
Is there any specific setting that needs to be used ? Or is there any other way of doing av_exrtaction to capture the Power network simulation ?
My main intention is to find the IR drop on the power network till the transistor nodes.
Priyankar
    Please contact customer support (I'm travelling this week so won't have time to answer this; others might, but customer support is your best bet here).
