  3. Modifying a string passed through pPar()
  • Views 16621
Roderick
Roderick over 9 years ago
I've got a couple of s-parameter files that I want to make symbols for so I can easily use them in my schematics. For that, I made a symbol (let's call it sparblock), and a schematic view that contains an nport from analogLib. On the properties of that nport I set the value for the data file to be pPar("filename").
If I now instantiate an sparblock in my schematic I can set the "filename" property to, say, "/data/models/spar/model1.sp" and everything works.
However, I'd like to make it a bit more user-friendly by not requiring the user to fill in the whole path, so I want to add the path in front of the filename. I changed the property of the nport to be
strcat("/data/models/spar/" pPar("filename"))
And then only have "model1.sp" on the sparblock property. However, Spectre now tells me
ERROR (SFE-874): "netlist" 7: Unexpected operator "/". Expected end of file or end of line.
So apparently it doesn't know how to interpret the strcat() expression. Is there a way to concatenate two strings on the property form like this?
    That's not surprising, as you can use AEL (Analog Expression Language) expressions in CDF parameter fields, but not SKILL.
    The simplest way of providing the path component is to use the Setup->Simulation Files->Include Path field in ADE. Then the actual components can just use the leaf filename, but the path can be specified as the include path in ADE.
    If you really want to do it via the component, you'd have to use a CDF callback on the level above to add the path onto the filename field. Probably not the best idea though as that would stop you really being able to use pPar() on that field to keep passing through the hierarchy.
