  3. problem when launching virtuoso IC 6.1.5 on rhel 6.8
  • Views 15925
tortiz96
tortiz96 over 9 years ago
Hello I get the following errors when trying to launch virtuoso on rhel 6. thanks
awk: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
sort: error while loading shared libraries: librt.so.1: cannot open shared object file: No such file or directory
/bin/ksh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
    You appear to be missing some shared libraries. Do you have /lib/libdl.so.2 and /lib/librt.so.1 or are these just in /lib64?
    If so, these come from the 32-bit version of the glibc rpm - on my machine I have:
    glibc-2.12-1.149.el6_6.5.i686
    glibc-2.12-1.149.el6_6.5.x86_64
    (first is 32 bit, second 64 bit).
  • tortiz96
    Hi I verified they are both in /lib and /lib64. And both 32 and 64 bit versions installed.
    They are links in /lib64
    librt.so.1 -> librt-2.12.so
    libdl.so.2 -> libdl-2.12.so
    root@linux-ws14 lib64]# rpm -q glibc
    glibc-2.12-1.192.el6.x86_64
    glibc-2.12-1.192.el6.i686
    Do you have $LD_LIBRARY_PATH or $LD_ASSUME_KERNEL set? If so, what are they set to?
