  3. Pins are not annotated using subcircuit (netlist)
  • Views 17357
Johanny Saenz
Johanny Saenz over 9 years ago
Hi all.
I'm following the procedure depicted on https://community.cadence.com/cadence_blogs_8/b/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade
My subckt declaration on the netlist matches with the pins on the symbol.
subckt adc_sh_comparator DVDD VDDA1 VDDA2 VSS VSSA1 \
VSSA2 cfg_cmp_i\(7\) cfg_cmp_i\(6\) cfg_cmp_i\(5\) cfg_cmp_i\(4\) \
cfg_cmp_i\(3\) cfg_cmp_i\(2\) cfg_cmp_i\(1\) cfg_cmp_i\(0\) \
cmp_3v3_o en_i isnk0_i isnk1_i isnk2_i isnk_pa1_i isnk_pa2_i \
isnk_pa3_i isrc_pa1_o isrc_pa2_o isrc_pa3_o track_i vdac_i vin_i \
vout_db_o vout_o vrefp_i
I tried the procedure with another schematic and it worked.
So I suspected that I have to clean or redefine some pin order.
Thanks in advance
    That's very interesting, but did you have a question or something that didn't work? If so, what was it?
  • Johanny Saenz
    Excuse me, for some reason I deleted the error line. When I run the simulation it gives me the following error:
    ERROR (SFE-45): "input.scs" 68: `COMP': An instance of `adc_sh_comparator' needs at least 31 terminals (but has only 0).
    The netlister is not annotated my pin order. So I suspect that I need to clean or redefine something on my view.
  • moralope
    moralope over 9 years ago
    Did you find a solution for this problem? I am facing the same issue when following that procedure to simulate a .spi netlist. It would be nice to know how you solved it.
    Thanks!
  • Johanny Saenz
    No. I didn't. You could try to recreate the symbol with the connectivity information from layout/schematic.
