  3. auCdl based netlisting
  • Views 20143
asetji
asetji over 9 years ago
I am under the process of migrating my design from an older PDK version to a newer version. In the older version, whenever I used to export my schematic to netlist via the export tool, at the end of the netlist of my block i used to get empty definitions of basic blocks like nfet/pfet  coming from the pdk library. However, in the newer pdk version, these empty definitions are not there anymore.
So, whenever I run LVS using this netlist, the LVS tools complains that the source netlist references but does not define the subckt. The LVS passes the moment I add these empty definitions.
I have checked that the export netlist form is same in new and old pdk.
The old pdk is using IC6.1.6, the newer pdk is using IC 6.1.7. For LVS, Calbre is being used.
BR
alok
    Alok,
    Please contact customer support. This is going to be pretty hard to debug without some specifics about the design kit being used, and doing that via customer support will be much easier (plus we can take a look at your setup).
  • asetji
    Hello Andrew,
    I will ask the permission from my supervisor to raise it to the support. Meanwhile, I noticed one warning in the CIW saying something on the line
    WARNING (AUCDL-46): Unable to read netlist from file 'cdl.netlist' specified by the "CDL_NETLIST_FILE" property of cellview 'PDK/nmos/auCdl' because the file does not exist. Ignoring this property for the current run. To read the netlist from this file, ensure that the specified file exists or specify a valid file location.
    The component it complains about is the same which is missing from the netlist
    BR
    alok
    Alok,
    You could open that view (PDK/nmos/auCdl) and edit the cellView properties (shift-Q is the usual bindkey) and look for this "CDL_NETLIST_FILE" property. Check to see what it's set to, and then see if that file exists (I think it would be within the view directory on disk).
    You can also compare with the earlier PDK which was working.
    It may be that you need to take this up with whoever provided the PDK.
