  3. Printing all DC operating points of all devices
  • Views 16880
Mamad
Mamad over 9 years ago
I am a beginner in ocean. I have the following ocean script which reports the source current of transistor M3.
openResults("~/simulation/TEST_OPAMP_POLY_TB/spectre/schematic/psf/")
p=outfile("/home/mt2775_loc/simulation/TEST_OPAMP_POLY_TB/spectre/schematic/netlist/resultsSpectre.txt" "w")
fprintf(p, "Hello World! to make sure it is working\n" )
selectResult('dcOp)
fprintf(p,"%f",i("/I0/M3/S"))
I also know if I use outputs() command, all DC values will be printed out.
The question is that which command can print all DC values into the file (instead of calling function "fprintf" for each one by one like above)? In short, I need a such command fprintf(p,"%f", outputs()).
If I need to use a loop would you please let me how to write it.
Thank for your help
Mohammad
    Potentially you could use the report() function with the dcOpInfo results to do something similar to what you want. Otherwise I think you'd need to use a foreach() loop on the result of outputs() and do the fprintf within that loop.
  • Mamad
    Dear Andrew,
    Thanks for your reply
    Mohammad
