  3. Changing the I/O Type of a Pin in Layout View Using SKI...
  • Views 3495
Changing the I/O Type of a Pin in Layout View Using SKILL
canbaltaci
canbaltaci over 9 years ago
I am using version IC6.1.6-64b.500.11.
I am creating a layout with some SKILL instructions. I would like to add a pin by defining some parameters like terminal name, I/O type etc. From what I have found from different sources, I got close to my goal with the following part of my code:
labelID = dbCreateLabel(cv list("M1" "label") 0.5:0.5 "testNet" "centerCenter" "R0" "stick" 1) ;this line seems not so critical but creates a label on the layout that makes it easy to observe the terminal names on the pins
netID = dbCreateNet(cv "testNet")
figID = dbCreateRect(cv list("M1" "label") list(0.0:0.0 1.0:1.0))
pinID = dbCreatePin(netID figID);
However, I was not able to change the I/O type. I have tried the following; however, when I open the layout view and check the properties of the square pin, the I/O type appears to be unused:
pinID~>direction="inputOutput"
Could you please help me regarding this issue?
One additional question: How can I observe the list of the attributes and parameters of an object (like rectangle, path etc.) that I can modify in SKILL?
Many thanks in advance.
Best regards,
Can
    Either explicitly create the terminal:
    dbCreateTerm(netID "testNet" "inputOutput")
    or use:
    pinID~>term~>direction="inputOutput"
    The direction belongs to the terminal, not the pin.
    To see all the attributes of an object, use obj~>? and to see the attributes and values, use obj~>??. Note that not all are editable - you can find that information out in the Virtuoso Design Environment SKILL Reference. It's structured slightly differently depending on the version, but you should find a section or chapter on the various attributes. Search for "Attributes of Cellviews" to find it (in the latest manuals it's in chapter 14).
  • canbaltaci
    Thank you very much Andrew, it helped me a lot.
    Best regards,
    Can
