  3. A few questions regarding using PSS for rectifier desig...
  • Views 18113
A few questions regarding using PSS for rectifier design
MenghanSun
MenghanSun over 9 years ago
Dear all,
I'm using PSS for rectifier simulation and try to look at the voltage and currents in steady state. I'm trying to improve the accuracy of the PSS and try to get the same results as in the transient simulation (after it settled).
Currently, I use the Harmonic Balance mode. However, I heard Shooting Newton is better as it is only a wrapper for transient simulation. But, personally, I find HB to be more stable. From reading the user manual, when the over_sampling factor is set to be very big, the accuracy is very high. But how big should we set to this over_sampling factor to be? The higher, the better? Also, is there any additional way to improve the accuracy of the pss simulation? max_iters?
Also, does PSS support multi-thread? How to activate this?
I found PSS HB sometimes giving the correct results (i.e. the same as transient), other times not giving the correct result. Is this because I'm not setting the convergence parameters properly?
I know the port element in cadence only provides power in reference to 50 Ohm. Could you please recommend a solution if we have to use a port that has complex impedance? For example, a rectifier driven by custom antenna whose impedance conjugatively matched to the rectifier.
I use mmsim14 + ic616.
Thank you very much,
Menghan
    Menghan,
    I suspect you would  be better off contacting customer support - it's hard to answer all your questions particularly without knowing quite what your circuit looks like. Some broad answers (to some of the questions):
    1. I'm not sure why you think HB is "more stable". If the circuit is a highly nonlinear circuit (or is a switching circuit) then generally shooting is preferable to harmonic balance, because it naturally follows sharp edges rather than relying on the solution being accurately found by specifying enough harmonics. With shooting the number of harmonics doesn't (significantly) affect the accuracy, whereas with harmonic balance the number of harmonics strongly affects the accuracy.
    2. The oversampling factor is a way to increase the number of points in the period where the frequency domain solution is converted back into the time domain. This can increase the accuracy when you have sharp transitions in the waveform and is not as expensive as increasing the number of harmonics. More harmonics increases the size of the solution, but oversample of 2 (say) means that  you are sampling at twice the number of points you would have got by the harmonics alone (2*harms+1). You still need enough harmonics to be able to reasonably represent the solution though. Typically I would use (if needed) oversample of 2 or 4 but rarely much higher than that. I suggest you ensure you have a good understanding of this rather than throwing random values at the problem (that's a good way of slowing down the simulation with little benefit)
    3. maxiters is unlikely to improve accuracy. Most of the time I leave this alone.
    4. The main way to improve accuracy is the errpreset setting, and then tightening reltol (a little further) if needed. For harmonic balance, the number of harmonics is also very important for accuracy.
    5. multithreading is supported for PSS (shooting and harmonic balance). You have to enable APS for this (on the Setup->High Performance form) and you can control the number of threads.
    6. I have no way of knowing why you're not getting the correct results - this is why you should contact customer support.
    7. You asked earlier about the port element - you don't have to use the port element - you can use vsource/isource too. Also, the port element can provide power with reference to whatever impedance you like. You can specify a complex impedance (when using harmonic balance) - there's a "harmonic port" option which allows you to specify different complex impedances at different harmonics. This can't be done in the time domain (shooting) because it's not physical - the impedance can't be discrete complex values at different impedances.
  • MenghanSun
    Thank you very much for your reply, Andrew.
    How to set reltol through the GUI (ADE)? For the accuracy parameters, I only see, iteratio, steadyratio, itres and I don't see reltol anywhere (in the simulation option forum).
    From reading spectre.out, it seems that reltol has been set to 1e-4 by default, errpreset = conservative. Is that a reasonable value? With this setting, I still observe about 1~2% (sometimes 3) discrepancy for results (e.g. rectifier's output DC). Does this sound reasonable to you?
    Many thanks,
    Menghan
    Hi Menghan,
    I'm not sure what this "discrepancy" is relative to; I would expect results to be more accurate with conservative and a relative tolerance of 1e-4, but I don't know what you're measuring or what you're comparing it with. So I can't comment if it's reasonable or not! That's why I suggested you contact customer support...
    The reltol is set on the Simulation->Options->Analog form, although I wouldn't advise wholesale setting of this parameter without knowing what you're doing. Maybe you can try setting it to 1e-5, but I have no idea what you're actually trying to do here.
    So I would strongly recommend contacting customer support.
  • MenghanSun
    Thank you very much for your help regarding the setting of reltol in the ADE, and the results did improve after setting reltol=1e-6
    I'm a PhD student, to contact the customer support, I have to go through a lengthy process with the university...
    Also, do you think tightening max_time_step will help further improve the simulation accuracy (for both transient and harmonic balance)?
    Menghan
    Generally messing with maxstep is unnecessary (it won't help harmonic balance anyway), and the better solution is to ask for more harmonics in shooting PSS (this affects maxacfreq, which in turn affects maxstep during the shooting interval)). I'm not sure why you refer to max_time_step as there's no such parameter in spectre. However, without knowing more detail, I don't like giving advice about changing a parameter without understanding the root cause of the accuracy issues. Andrew
