  3. layer map file for GDS transfer to virtuoso
  • Replies 9
  • Views 34793
oAwad
oAwad over 9 years ago
Hello all,
I have a GDS layout previously designed in SoC encounter, I want to import it in Virtuoso but I don't have a layer map provided with PDK (I'm using Nangate Open Cell Library 45nm). I now have two files; a technology file provided with PDK and a streamOut.map file generated from GDS export in Encounter.
Here is the technology file:
; Technology File NCSU FreePDK 45nm
; LAYER DEFINITION
layerDefinitions(
 techLayers(
 ;( LayerName                 Layer#     Abbreviation )
  ( IP                        63         IP )
  ( nwell                     3          nwell )
  ( pwell                     2          pwell )
  ( nimplant                  4          nimplant )
  ( pimplant                  5          pimplant )
  ( active                    1          active )
  ( vtg                       6          vtg )
  ( vth                       7          vth )
  ( thkox                     8          thkox )
  ( poly                      9          poly )
  ( contact                   10         contact )
  ( metal1                    11         metal1 )
  ( via1                      12         via1 )
  ( metal2                    13         metal2 )
  ( via2                      14         via2 )
  ( metal3                    15         metal3 )
  ( via3                      16         via3 )
  ( metal4                    17         metal4 )
  ( via4                      18         via4 )
  ( metal5                    19         metal5 )
  ( via5                      20         via5 )
  ( metal6                    21         metal6 )
  ( via6                      22         via6 )
  ( metal7                    23         metal7 )
  ( via7                      24         via7 )
  ( metal8                    25         metal8 )
  ( via8                      26         via8 )
  ( metal9                    27         metal9 )
  ( via9                      28         via9 )
  ( metal10                   29         metal10 )
  ( DRC                       400        DRC )
 ) ;techLayers
 techLayerPurposePriorities(
 ;layers are ordered from lowest to highest priority
 ;( LayerName                 Purpose    )
  ( IP                        drawing )
  ( nwell                     drawing )
  ( pwell                     drawing )
  ( nimplant                  drawing )
  ( pimplant                  drawing )
  ( active                    drawing )
  ( vtg                       drawing )
  ( vth                       drawing )
  ( thkox                     drawing )
  ( poly                      drawing )
  ( contact                   drawing )
  ( metal1                    drawing )
  ( via1                      drawing )
  ( metal2                    drawing )
  ( via2                      drawing )
  ( metal3                    drawing )
  ( via3                      drawing )
  ( metal4                    drawing )
  ( via4                      drawing )
  ( metal5                    drawing )
  ( via5                      drawing )
  ( metal6                    drawing )
  ( via6                      drawing )
  ( metal7                    drawing )
  ( via7                      drawing )
  ( metal8                    drawing )
  ( via8                      drawing )
  ( metal9                    drawing )
  ( via9                      drawing )
  ( metal10                   drawing )
  ( DRC                       drawing )
 ) ;techLayerPurposePriorities
 techDisplays(
 ;( LayerName    Purpose      Packet          Vis Sel Con2ChgLy DrgEnbl Valid )
  ( IP           drawing      PacketName_0     t t t t t )
  ( nwell        drawing      PacketName_2     t t t t t )
  ( pwell        drawing      PacketName_3     t t t t t )
  ( nimplant     drawing      PacketName_4     t t t t t )
  ( pimplant     drawing      PacketName_5     t t t t t )
  ( active       drawing      PacketName_6     t t t t t )
  ( vtg          drawing      PacketName_11    t t t t t )
  ( vth          drawing      PacketName_12    t t t t t )
  ( thkox        drawing      PacketName_13    t t t t t )
  ( poly         drawing      PacketName_14    t t t t t )
  ( contact      drawing      PacketName_19    t t t t t )
  ( metal1       drawing      PacketName_26    t t t t t )
  ( via1         drawing      PacketName_30    t t t t t )
  ( metal2       drawing      PacketName_31    t t t t t )
  ( via2         drawing      PacketName_35    t t t t t )
  ( metal3       drawing      PacketName_36    t t t t t )
  ( via3         drawing      PacketName_40    t t t t t )
  ( metal4       drawing      PacketName_41    t t t t t )
  ( via4         drawing      PacketName_45    t t t t t )
  ( metal5       drawing      PacketName_46    t t t t t )
  ( via5         drawing      PacketName_50    t t t t t )
  ( metal6       drawing      PacketName_51    t t t t t )
  ( via6         drawing      PacketName_55    t t t t t )
  ( metal7       drawing      PacketName_56    t t t t t )
  ( via7         drawing      PacketName_60    t t t t t )
  ( metal8       drawing      PacketName_61    t t t t t )
  ( via8         drawing      PacketName_65    t t t t t )
  ( metal9       drawing      PacketName_66    t t t t t )
  ( via9         drawing      PacketName_70    t t t t t )
  ( metal10      drawing      PacketName_71    t t t t t )
  ( DRC          drawing      PacketName_77    t t t t t )
 ) ;techDisplays
) ;layerDefinitions
and here is the streamOut.map file:
metal1 NET 1 0
metal1 SPNET 2 0
metal1 PIN 3 0
metal1 LEFPIN 4 0
metal1 FILL 5 0
metal1 FILLOPC 6 0
metal1 VIA 7 0
metal1 VIAFILL 8 0
metal1 VIAFILLOPC 9 0
metal1 LEFOBS 10 0
NAME metal1/NET 11 0
NAME metal1/SPNET 12 0
NAME metal1/PIN 13 0
NAME metal1/LEFPIN 14 0
via1 LEFPIN 15 0
via1 FILL 16 0
via1 FILLOPC 17 0
via1 VIA 18 0
via1 VIAFILL 19 0
via1 VIAFILLOPC 20 0
metal2 NET 21 0
metal2 SPNET 22 0
metal2 PIN 23 0
metal2 LEFPIN 24 0
metal2 FILL 25 0
metal2 FILLOPC 26 0
metal2 VIA 27 0
metal2 VIAFILL 28 0
metal2 VIAFILLOPC 29 0
metal2 LEFOBS 30 0
NAME metal2/NET 31 0
NAME metal2/SPNET 32 0
NAME metal2/PIN 33 0
NAME metal2/LEFPIN 34 0
via2 LEFPIN 35 0
via2 FILL 36 0
via2 FILLOPC 37 0
via2 VIA 38 0
via2 VIAFILL 39 0
via2 VIAFILLOPC 40 0
metal3 NET 41 0
metal3 SPNET 42 0
metal3 PIN 43 0
metal3 LEFPIN 44 0
metal3 FILL 45 0
metal3 FILLOPC 46 0
metal3 VIA 47 0
metal3 VIAFILL 48 0
metal3 VIAFILLOPC 49 0
metal3 LEFOBS 50 0
NAME metal3/NET 51 0
NAME metal3/SPNET 52 0
NAME metal3/PIN 53 0
NAME metal3/LEFPIN 54 0
via3 LEFPIN 55 0
via3 FILL 56 0
via3 FILLOPC 57 0
via3 VIA 58 0
via3 VIAFILL 59 0
via3 VIAFILLOPC 60 0
metal4 NET 61 0
metal4 SPNET 62 0
metal4 PIN 63 0
metal4 LEFPIN 64 0
metal4 FILL 65 0
metal4 FILLOPC 66 0
metal4 VIA 67 0
metal4 VIAFILL 68 0
metal4 VIAFILLOPC 69 0
metal4 LEFOBS 70 0
NAME metal4/NET 71 0
NAME metal4/SPNET 72 0
NAME metal4/PIN 73 0
NAME metal4/LEFPIN 74 0
via4 LEFPIN 75 0
via4 FILL 76 0
via4 FILLOPC 77 0
via4 VIA 78 0
via4 VIAFILL 79 0
via4 VIAFILLOPC 80 0
metal5 NET 81 0
metal5 SPNET 82 0
metal5 PIN 83 0
metal5 LEFPIN 84 0
metal5 FILL 85 0
metal5 FILLOPC 86 0
metal5 VIA 87 0
metal5 VIAFILL 88 0
metal5 VIAFILLOPC 89 0
metal5 LEFOBS 90 0
NAME metal5/NET 91 0
NAME metal5/SPNET 92 0
NAME metal5/PIN 93 0
NAME metal5/LEFPIN 94 0
via5 LEFPIN 95 0
via5 FILL 96 0
via5 FILLOPC 97 0
via5 VIA 98 0
via5 VIAFILL 99 0
via5 VIAFILLOPC 100 0
metal6 NET 101 0
metal6 SPNET 102 0
metal6 PIN 103 0
metal6 LEFPIN 104 0
metal6 FILL 105 0
metal6 FILLOPC 106 0
metal6 VIA 107 0
metal6 VIAFILL 108 0
metal6 VIAFILLOPC 109 0
metal6 LEFOBS 110 0
NAME metal6/NET 111 0
NAME metal6/SPNET 112 0
NAME metal6/PIN 113 0
NAME metal6/LEFPIN 114 0
via6 LEFPIN 115 0
via6 FILL 116 0
via6 FILLOPC 117 0
via6 VIA 118 0
via6 VIAFILL 119 0
via6 VIAFILLOPC 120 0
metal7 NET 121 0
metal7 SPNET 122 0
metal7 PIN 123 0
metal7 LEFPIN 124 0
metal7 FILL 125 0
metal7 FILLOPC 126 0
metal7 VIA 127 0
metal7 VIAFILL 128 0
metal7 VIAFILLOPC 129 0
metal7 LEFOBS 130 0
NAME metal7/NET 131 0
NAME metal7/SPNET 132 0
NAME metal7/PIN 133 0
NAME metal7/LEFPIN 134 0
via7 LEFPIN 135 0
via7 FILL 136 0
via7 FILLOPC 137 0
via7 VIA 138 0
via7 VIAFILL 139 0
via7 VIAFILLOPC 140 0
metal8 NET 141 0
metal8 SPNET 142 0
metal8 PIN 143 0
metal8 LEFPIN 144 0
metal8 FILL 145 0
metal8 FILLOPC 146 0
metal8 VIA 147 0
metal8 VIAFILL 148 0
metal8 VIAFILLOPC 149 0
metal8 LEFOBS 150 0
NAME metal8/NET 151 0
NAME metal8/SPNET 152 0
NAME metal8/PIN 153 0
NAME metal8/LEFPIN 154 0
via8 LEFPIN 155 0
via8 FILL 156 0
via8 FILLOPC 157 0
via8 VIA 158 0
via8 VIAFILL 159 0
via8 VIAFILLOPC 160 0
metal9 NET 161 0
metal9 SPNET 162 0
metal9 PIN 163 0
metal9 LEFPIN 164 0
metal9 FILL 165 0
metal9 FILLOPC 166 0
metal9 VIA 167 0
metal9 VIAFILL 168 0
metal9 VIAFILLOPC 169 0
metal9 LEFOBS 170 0
NAME metal9/NET 171 0
NAME metal9/SPNET 172 0
NAME metal9/PIN 173 0
NAME metal9/LEFPIN 174 0
via9 LEFPIN 175 0
via9 FILL 176 0
via9 FILLOPC 177 0
via9 VIA 178 0
via9 VIAFILL 179 0
via9 VIAFILLOPC 180 0
metal10 NET 181 0
metal10 SPNET 182 0
metal10 PIN 183 0
metal10 LEFPIN 184 0
metal10 FILL 185 0
metal10 FILLOPC 186 0
metal10 VIA 187 0
metal10 VIAFILL 188 0
metal10 VIAFILLOPC 189 0
metal10 LEFOBS 190 0
NAME metal10/NET 191 0
NAME metal10/SPNET 192 0
NAME metal10/PIN 193 0
NAME metal10/LEFPIN 194 0
NAME COMP 195 0
COMP ALL 196 0
DIEAREA ALL 197 0
Please anyone give me a hint how to map my layer correctly to virtuoso.
    I'd be surprised if the NCSU FreePDK doesn't come with a layer map file. That said, I would have thought it's not to difficult to map the layer/datatype numbers used to the layer/purpose names used in the PDK - it's a straightforward enough and well documented format.
  • oAwad
    I searched in NangateOpenCellLibrary 45nm but didn't find any. Can you give me some hints how to modify the streamOut.map file according to the provided technology file ? or just direct me to good resources.
    Should I change all layer purpose to "drawing" and/or modify layer numbers ?
  • oAwad
    If anyone can explain the purpose of map file and how to modify the map file, I'll be more than grateful. Thanks
    I took a look at the NCSU FreePDK45 (there's a link to download it from here after you've registered), and it doesn't contain a layer map file. From looking at the library, dumping the tech file, and comparing the layer numbers with those used in the various DRC and LVS rule files in the PDK, I can see that the OA/Virtuoso layer numbers correspond to the layer numbers in those rule files - so generally that means you wouldn't need a layer mapping file because the layer numbers for stream directly correspond to the OA/Virtuoso layer numbers.
    However, if you really needed one, you'd use:
    active drawing 1 0
    pwell drawing 2 0
    nwell drawing 3 0
    nimplant drawing 4 0
    pimplant drawing 5 0
    vtg drawing 6 0
    vth drawing 7 0
    thkox drawing 8 0
    poly drawing 9 0
    contact drawing 10 0
    metal1 drawing 11 0
    via1 drawing 12 0
    metal2 drawing 13 0
    via2 drawing 14 0
    metal3 drawing 15 0
    via3 drawing 16 0
    metal4 drawing 17 0
    via4 drawing 18 0
    metal5 drawing 19 0
    via5 drawing 20 0
    metal6 drawing 21 0
    via6 drawing 22 0
    metal7 drawing 23 0
    via7 drawing 24 0
    metal8 drawing 25 0
    via8 drawing 26 0
    metal9 drawing 27 0
    via9 drawing 28 0
    metal10 drawing 29 0
    nodrc drawing 80 0
    Note these numbers don't correspond to what you have in the stream map for Encounter. I'm not so familiar with Encounter, but a quick search on support.cadence.com gave me:
    Also this article:
    You may need to define a suitable layer map file for streaming out from encounter to match the stream layer numbers used in virtuoso and the physical verification tools; it looks as if the layer map file it generated was just an automatically generated file. You can probably adapt it to stream the data back into virtuoso, but it might be simpler to map it properly on the way out of Encounter.
    Overall though, this question would probably be best sent to NCSU - although it wasn't clear to me from the web sites how you contact them for assistance/guidance.
    Regards
  • oAwad
    Thank you Andrew,
    I will contact NCSU (eda_help@ncsu.edu **found in their PDK). Should I try attaching the map file you wrote during Encounter GDS export ?
    You might still need to adapt it so that the layer/purpose names match what is defined in the LEF (i.e. what they are called in Encounter). I suspect they're not called precisely the same thing... (I think metal1 NET rather than metal1 drawing).
  • oAwad
    In LEF file, metal1 type is "routing". I read this statement in Encounter User Guide :
    "Note: In routing layers, using ALL is the same as using NET, SPNET, VIA, PIN, LEFPIN, FILL, LEFOBS, and VIAFILL. In cut layers, using ALL is the same as using VIA or VIAFILL."
    So taking this part from streamOut.map file:
    metal1 NET 1 0
    metal1 SPNET 2 0
    metal1 PIN 3 0
    metal1 LEFPIN 4 0
    metal1 FILL 5 0
    metal1 FILLOPC 6 0
    metal1 VIA 7 0
    metal1 VIAFILL 8 0
    metal1 LEFOBS 10 0
    via1 LEFPIN 15 0
    via1 FILL 16 0
    via1 FILLOPC 17 0
    via1 VIA 18 0
    via1 VIAFILL 19 0
    I need to tell Encounter to map all metal1 layers to be "metal1 drawing 11 0", all NAME layers to be "metal1 label 11 0" and all via1 layers to be "via1 drawing 12 0" as required by Virtuoso.
    How can I do that using a layer map file that I'll attach it to Encounter GDS export ?
    Also, what about this section: (it's not included in the automatically generated streamOut.map file by Encounter)
    active drawing 1 0
    pwell drawing 2 0
    nwell drawing 3 0
    vtg drawing 6 0
    vth drawing 7 0
    thkox drawing 8 0
    poly drawing 9 0
    The only information related to this part in the LEF file is
    "LAYER poly
    TYPE MASTERSLICE ;
    END poly
    LAYER active
    TYPE MASTERSLICE ;
    END active"
    As I've said before, Encounter (or Innovus) are not products that I generally cover, so I can't (personally) really answer the above. Potentially you'd be better off asking this in the Digital Implementation forum.
    My guess is that you alter all the metal1 entries to have "11 0" at the end, and so on. According tp the documentation you can reference the mapping file through the UI or using the -mapFile argument of the streamOut command.
    I wouldn't expect the stream file from Encounter to contain any of those layers (active, nwell, pwell etc) because these would be in the standard cells and not in the routing that Encounter is producing.
  • oAwad
    Thanks Andrew !
    Actually this was the point to attach the map file with correct layers in Encounter GDS export and I didn't need to attach the map file during streamIn in Virtuoso and everything worked perfectly. Thank you again!
