  3. Generating a bit stream in Virtuoso
  • Views 18374
oAwad
oAwad over 9 years ago
Hello all,
I want to test a digital chip on Cadence Spectre using its extracted SPICE netlist from Calibre PEX. The chip has a bit stream of 128 bits as input and its outputs are:  a digital bit stream of 128 bits and an analog signal. So what is the best way to generate the input bit stream ?
I found a way using vbit source and loading a bit stream to it using a txt file, but is there a better way ?
    By "128 bits" do you mean it's 128 bits wide?
    If so, you are probably going to be better creating a vector file - this is available via the Setup->Simulation Files form in ADE and is documented in a chapter in the Ultrasim User Guide (on "Digital Vector File Format").
    See this recent thread on vector files (just FYI - it gives some examples, at least).
