  3. QRC extraction problem
  • Views 16722
umais
umais over 9 years ago
Hi all:
I'm at QRC stage now where I have encountered this extraction problem:
Cadence Extraction QRC - 64-bit Parasitic Extractor - Version 13.2.0-s451
Tue Jul 22 19:35:08 PDT 2014
Copyright 2013 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
WARNING (LBRCXM-624): Warning [input]: Line 8: 'well' statement is ignored in ICT file line.
WARNING (LBRCXM-624): Warning [input]: Line 10: 'well' statement is ignored in ICT file line.
INFO (LBRCXM-624): No temperature processing will occur for the layer CONT, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer VIA1, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer VIA2, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer VIA3, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer VIA4, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer VIAF, because this layerhas no Tc1 and Tc2.
INFO (LBRCXU-108): Starting
/opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/rcxToDfII /home/cds/ee642_project_umais/d1/__qrc.rcx_cmd -t -f /home/cds/ee642_project_umais/d1/extview.tmp -w /home/cds/ee642_project_umais/d1 -cdslib /home/cds/ee642_project_umais/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.6-64b:IC6.1.6-64b.101 08/06/2013 14:01 (sjfnl785) $
sub-version 4.1_USR4, integ signature 2013-08-06-1301
run on cdspc from /opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/64bit/rcxToDfII on Sun Mar 12 10:42:10 2017
*WARNING* Technology must be specified!
*LF-INFO* Loading cmos150/cmos150.skill/cmos150_cdfCbks.il done
*LF-INFO* cmos150 libInit.il loaded successfully.
*LF-INFO* Loading cmos150hv/cmos150hv.skill/cmos150hv_cdfCbks.il done
*LF-INFO* cmos150hv libInit.il loaded successfully.
*ERROR* No library model for device "nmosld40v_4 auLvs cmos150hv".
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nmosld40v_4 auLvs) from lib (cmos150hv) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
*WARNING* (DB-220704): The Pcell super master: cmos150/break/auLvs is not a SKILL super master.
The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
*WARNING* (DB-220704): The Pcell super master: cmos150/make/auLvs is not a SKILL super master.
ERROR: Assura is terminating because some library models do not exist.
Your rules and your dfII model libraries are inconsistent.
Assura requires all library models in the rule file be present
in the database when running rcx with the "extracted_view"
option.
INFO (LBRCXU-111): Warning /opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/rcxToDfII exit with bad status
INFO (LBRCXU-112): Warning Status 256
INFO (LBRCXU-113): Warning QRC execution terminated
***** aveng fork terminated abnormally *****
If anyone has fixed such an error or knows how please help
    Turn this switch off on the QRC form:
    The default behaviour is that it checks that all devices referenced in the QRC setup can be found, regardless of whether they are used in your layout. With this turned off, it doesn't do that.
  • umais
    Thanks Andrew
    I have done this. Now there comes another error:
    /opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/rcxToDfII /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz/__qrc.rcx_cmd -t -f /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz/extview.tmp -w /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz -cdslib /home/cds/ee642_project_umais/cds.lib
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.04s.
    run on cdspc from /opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/64bit/rcxToDfII on Sun Mar 12 11:54:48 2017
    INFO (LBRCXU-114): Finished /opt/cadence/installs/ASSURA41/tools.lnx86/assura/bin/rcxToDfII
    INFO (LBRCXM-642): Constructing the RCX run script
    /opt/cadence/installs/EXT132/tools.lnx86/extraction/bin/64bit//capgen: error while loading shared libraries: libtermcap.so.2: cannot open shared object file: No such file or directory
    INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
    /opt/cadence/installs/EXT132/tools.lnx86/extraction/bin/64bit//capgen -techdir /opt/PDK/PDK_LF15Ai_V0_5_0/pv/qrc/6metal/typ -lvs /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz.xcn -p2lvs /opt/PDK/PDK_LF15Ai_V0_5_0/pv/qrc/6metal/typ/qrcTechFile -reseqn -sw3d -blocking _ngate_cap_m_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_m_dnw:0.1,STI,DIFF,POLY2 -blocking _pgate_cap_m:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_dnw:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_dnw:0.1,STI,DIFF,POLY2 -blocking mim1c:0.6,STI,METAL5,METALF -p POLY2,allGate,DIFF -length_units meters -genericMos _nmos_ll_sal1,D,G,S -genericMos _nmos_3_sal,D,G,S -genericMos _nmos_5_sal,D,G,S -genericMos _pmos_ll_sal1,D,G,S -genericMos _pmos_3_sal,D,G,S -genericMos _pmos_5_sal,D,G,S /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz
    Forking: /opt/cadence/installs/EXT132/tools.lnx86/extraction/bin/64bit//capgen -techdir /opt/PDK/PDK_LF15Ai_V0_5_0/pv/qrc/6metal/typ -lvs /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz.xcn -p2lvs /opt/PDK/PDK_LF15Ai_V0_5_0/pv/qrc/6metal/typ/qrcTechFile -reseqn -sw3d -blocking _ngate_cap_m_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_m_dnw:0.1,STI,DIFF,POLY2 -blocking _pgate_cap_m:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_dnw:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_dnw:0.1,STI,DIFF,POLY2 -blocking mim1c:0.6,STI,METAL5,METALF -p POLY2,allGate,DIFF -length_units meters -genericMos _nmos_ll_sal1,D,G,S -genericMos _nmos_3_sal,D,G,S -genericMos _nmos_5_sal,D,G,S -genericMos _pmos_ll_sal1,D,G,S -genericMos _pmos_3_sal,D,G,S -genericMos _pmos_5_sal,D,G,S /home/cds/ee642_project_umais/monticelli1986testing2.3startupcombinedbhybrid1lfv2bsingcurvepush13.56MHz
    ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
    INFO (LBRCXM-709): ***** QRC terminated abnormally *****
    I have libtermcap.so.2 file in
    /lib/libtermcap.so.2
    /lib64/libtermcap.so.2
    But when I try to open the file it says: "This link cannot be used because its target “/lib64/libncurses.so.5.9” doesn't exist"
    Please let me know any suggestions to resolve this issue.
    Thanks in Advance.
    Umais
    Umais,
    I'm not sure what you mean "when I try to open the file". Open with what?
    I'd check what "ls -l /lib64/libtermcap.so.2" shows, and also "ls -lL /lib64/libtermcap.so.2". These libraries should come from the "compat-libtermcap" rpm, and the libncurses should come from the "ncurses-libs" rpm. I'd make sure that you have both installed.
    Looking at various QRC versions, EXT152 and later doesn't seem to require libtermcap.so.2 but does require libncurses (for capgen, at least).
    You can always check shared library bindings with:
     ldd /cds/lnx86/EXT151_latest/tools/extraction/bin/64bit/capgen
    and similar for the path to whichever you're using.
