  3. Change a technology library into a design library
  • Views 20760
Qilong
Qilong over 9 years ago
Hi All,
 Due to my mistake I set up a design library as a technology library and built quite some designs in it. Is there any way that I can change it back to a design library? I played with the Technology file manager but found no way to do that...
  Virtuoso version: 6.1.6
Best regards,
Qilong
    Hi Qilong,
    There are some SKILL functions to do the basic operations, which I've encapsulated in this utility code:
    /* abConvertRefToAttach.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 15, 2010
    Modified
    By
    Convert a referenced technology library (or one with its own
    tech database) into one that is attached to another library.
    Bit cleaner than just removing the tech.db
    Usage:
    abConvertRefToAttach("libName" "techLibName")
    SCCS Info: @(#) abConvertRefToAttach.il 03/13/17.14:30:48 1.1
    (defun abConvertRefToAttach (libName attachLibName "tt")
      (let (libId techId attachLibId attachTechId)
        (unless (setq libId (ddGetObj libName))
          (error "Could not access library %s\n" libName))
        (setq techId (techGetTechFile libId))
        (unless (equal (getq techId libName) libName)
          (error "Library is already attached to tech library %s\n"
                 (getq techId libName)))
        (unless (setq attachLibId (ddGetObj attachLibName))
          (error "Could not access library %s\n" attachLibName))
        (setq attachTechId (techGetTechFile attachLibId))
        (techDeleteTechFile techId)
        (techBindTechFile
          libId (getq attachTechId libName) (getq attachTechId fileName))
        t
  • Qilong
    I ran the script and it works. You helped me a lot. Thanks you very much!
    Best regards,
    Qilong
