  3. Virtuoso Layout L: Show/remove hidden/old (metal) layer...
  • Views 5580
Virtuoso Layout L: Show/remove hidden/old (metal) layers
itos
itos over 9 years ago
I have a design which I migrated from a 10 metal stack to a 8 metal stack.
It seems that the two "unsupported" metal stacks are still in the layout but I do not find any way to show and remove them. They are not listed as layers (because they do not exist in this PDK).
When I run DRC, I get the error of the unsupported metal layers. After clicking on the DRC error, the regions are highlighted where the metals are (and are supposed to be). But I find no way to mark and remove them.
Thanks!
  • Quek
    Quek over 9 years ago
    Hi itos
    This is a common problem when re-using layouts from processes with different metalstacks. You can read more about the solution from COS article 11717756.
    Best regards
    Quek
  • itos
    Hi Quek,
    Thank you. Unfortunately I cannot access this any more: "Account Expired, Your account is expired.".
    If it's not a big secret - could you tell me?
    Thanks!
  • Quek
    Hi itos
    No problem, please keep this to yourself and don't tell the other forum users. : )
    Would you please try this in CIW?
    cv=geGetWindowCellView()
    shapeList=setof(x cv~>shapes !x~>layerName)
    foreach( shape shapeList
       dbDeleteObject(shape)
    ) ;foreach
    The invisible shapes will only have "nil" as the layer name. They will be captured by the setof cmd and then be deleted.
    Best regards
    Quek
  • itos
    Hi Quek,
    Awesome, thanks!!
    The shapeList is empty for me, unfortunately. If I try shapeList=setof(x cv~>shapes x~>layerName) I get a long list of entries;
    however, shapeList=setof(x cv~>shapes !x~>layerName) returns just nil, i.e. no objects found.
    However, while playing around with this I somehow managed to make these metal layers visible and could delete them manually ...
