  3. modeling device using Verilog-A and having convergence ...
  • Views 16551
modeling device using Verilog-A and having convergence problems
funfet
funfet over 9 years ago
I'm new to Verilog-A I am having convergence issues with a device I modeled in Verilog-A. When I have the device simulated in parallel with a time varying voltage source then the simulation seems to work okay. The issues arise when I try to simulate transient behaviour of my device in series with an added resistor and the voltage source in parallel with both the series resistor and Verilog-A device (as seen in image if I added it correctly).
The code for the device is below.
[CODE]
`include "constants.vams"
`include "disciplines.vams"
module test_func(p,n);
    inout p,n;
    electrical p,n;
    //files for reading/writing
    integer mcd, fp;
    real data, v_present, v_step;
    real preisach_density[0:256];// all elements should add up to 1
    real domain_states[0:256];// all elements should be -1 or +1 (depending on polarity)
    real polarization;//polarization (between -Pr and +Pr)
    real polarization_prev, polarization_next;
    real time_prev, time_next;
    integer i, j, k;//used in loops
    integer rows, columns;//describes area scanned from applied voltage
    integer rows_total, columns_total;//gives number of rows and columns in the grid ("rows" and "columns" should not exceed these values)
    analog begin
        @(initial_step) begin
            //read data from csv file and transfer it to verilog-A array variable
            //data stored in csv file should be preisach distribution
            //csv file should have the same number of elements as arrays "preisach_density" and "domain_states"
            mcd=$fopen("test6.csv","r");
            while (!$feof(mcd)) begin
                $fscanf(mcd,"%f", preisach_density[i]);
                domain_states[i] = 1;
                i = i+1;
                  end
        //****************** v_step should be changed, should equal resolition of grid spacing
        v_step = 0.1; //arbitrary
        rows_total = 1.6/v_step;//the maximum anticipated applied input voltage divided by the resolution of the grid cells
        columns_total = 1.6/v_step;//the minimum anticipated applied input voltage divided by the resolution of the grid cells
        polarization_prev = 0;
        time_prev = 0;
        time_next = 0;
        end
        if (V(p,n) < 0) begin
            rows = V(p,n)/(-v_step);
            for(j = 0; j < columns_total; j=j+1) begin
                for(k=0; k<rows; k=k+1) begin
                    domain_states[k*columns_total + j] = -1;
                end
            end
        end
        if (V(p,n) > 0) begin
            columns = V(p,n)/(v_step);
            //value compared to j should equal number of columns in array
            for (j=0; j<columns * rows_total ; j=j+1) begin
                domain_states[j] = 1;
            end
        end
        polarization = 0;
        for (i=0; i<columns_total*rows_total; i = i+1) begin
            polarization = polarization + preisach_density[i]*domain_states[i];
        end
        polarization_prev = polarization_next;
        polarization_next = polarization;
        time_prev = time_next;
        time_next = $abstime;
        I(p,n) <+ (polarization_next - polarization_prev)/(time_next - time_prev);
    end
endmodule
[/CODE]
The error I get is:
Error (SPECTRE-16080): No DC solution found
I also get "Array access out of bounds" errors when the device is simulated in the circuit shown but this does not occur when it's just the device in parallel with the voltage source with no resistor. Does anyone have suggestions for how I can solve these issues?
    It's quite hard to debug with just the Verilog-A code and a picture of the schematic. For a start, it would be hard to reproduce without the "test6.csv" file that you reference in the model, and hard without knowing what the PWL source is doing (so providing the input.scs would help). That said, the PWL source probably doesn't affect the DC convergence (other than knowing what the DC and/or time 0 value of the source is).
    One thing that jumps out is that there's no transition-type statement on the current contribution at the end, which would mean that any changes in current are instantaneous, which could cause problems. Similarly there would be (I think) a divide by zero error in the DC because there's no time difference and so the denominator in the equation at the end will be 0.
    If that little hint doesn't help, you'll have to post the full example or better still go through customer support - this may take more time than can really give it because the model is reasonably complex to understand (there's no comments to describe what it's actually trying to model).
