  3. Operating point parameters for BSIM-IMG devices
  • Views 19106
Raghu Rao
Raghu Rao over 9 years ago
DC Operating point info for devices using BSIM-IMG model (mainstream model for FDSOI transistors) seems to contain only charge and capacitance information.
BSIM transistor models have traditionally included relative terminal voltages, transconductance, threshold voltage, etc. which are very useful for design. They're included in Operating point parameters for BSIM4, BSIM-CMG and even UTSOI (non-VT based model) models. Wondering if there's a reason they're excluded for BSIM-IMG devices or if they're just not included because the model is used relatively rarely. Does anyone have insights into this? The question is probably too specific - but any insight is much appreciated! :)
    Which simulator are you talking about? In spectre there's a fairly rich set of Operating point parameters for both bsimimg and utsoi models. Type either "spectre -h bsimimg" or "spectre -h utsoi" in a terminal window and then enter:
    /Operating
    You'll then see a reasonable list of parameters.
    I suspect you're using an old version of MMSIM. In versions before MMSIM141 (this changed some time during MMSIM141 and is certainly in MMSIM151) the operating point parameters for bsimimg became much more comprehensive.
  • Raghu Rao
    Thanks for the quick reply, Andrew!
    I'm using Spectre from MMSIM141. I checked both spectre -h output and the device models reference (Virtuoso Simulator Components and Device Models Reference) before posting. For MMSIM141, they only have charge and capacitance information for BSIM-IMG. The issue is singular for BSIM-IMG, though. UTSOI or BSIM-CMG don't have the problem as you pointed out.
    Thanks for the tip on MMSIM151. Will install the upgrade and try with it.
  • Raghu Rao
    Just wanted to add that the Spectre version I'm currently using currently is 14.1.0 (64bit, 04/28/2015)
    This changed in a hotfix (ISR) of MMSIM141; it must just be that you are using a subversion from before the fix...
  • Raghu Rao
    I was using MMSIM141 ISR7 (14.10.576). I upgraded to MMSIM151 (15.10.727) and can confirm that it is no longer an issue with the new version. The noise model seems to be more accurate too (surprising how different noise results are between the two versions!).
    Thanks again for the support! This was really helpful.
    The earlier version had an early (and quite limited) implementation of bsimimg; over time more versions have been added as the model has been developed. In the later MMSIM151 version you're using, there's support for versions 102.60, 102.61, 102.70 and 102.80 of the model.
