  3. SPECTRE ASSERTS INFO: Invoking psf2ferret...Failed
  • Views 15476
SomanP
SomanP over 9 years ago
I am getting following ERROR in ADEXL.  It is a tran run.
But, If I run it in the "test editor" or the "open debug environment" ,  the run completes properly and gives result.
Kindly help me to resolve the issue.
I am using Virtuoso 6.1.6
------------------- ERROR message in CIW --------------------------
*** SPECTRE ASSERTS INFO: Invoking psf2ferret...Failed
Error : psf2ferret failed to convert assert violations psf to sqlite
Soman
    Soman,
    psf2ferret is not a Cadence tool; I found a few CCRs related to this, but they're all from the same customer (I don't want to mention the name in the forums, but searching for your name in our support system shows you working for the same company.
    You should follow this up with your local CAD/EDA support.
  • SomanP
    Thanks a lot Andrew...
