  3. Virtuoso Spice In grouping instances
  • Views 15401
shredds
shredds over 9 years ago
I am trying to import a CDL netlist into virtuoso. I am able to succesfully import the design but it is very hard to read the design. Currently I see that instances which can be generally grouped as a bus are also expanded when I import it. For example suppose I have this in the cdl netlist
X1 A<1> VDD VSS B<1> mux
X2 A<2> VDD VSS B<2> mux
X100 A<100> VDD VSS B<100> mux
The import creates a different instance for each of these instances. If instead there was an option to make it a bus based instantiation it would make the schematic so much more readable and compact.t
Is there any option to do this? Either during import or I don't mind having to run a skill after as well.
Please help out here as I have too big a netlist.
Shraddha
    Shraddha,
    There is no support for merging split iterated instances such as this in SPICEIN. There are a few related CCRs asking for this, such as CCR 424977 and 1557670, but neither are planned currently. You can't combine them the netlist before import because that's not valid SPICE or CDL.
  • shredds
    Ah..shoot.. Anyways Thanks for the quick response Andrew.. :)
