  3. Floorplanner generate physical hierarchy
  • Views 14577
RVERP
RVERP over 9 years ago
Hello, I have two questions about the generate physical hierarchy of the floorplanner tool.
  1. In "generate physical hierarchy", there are always some blocks that have Param Changed indicated as YES. They are set to regenerate, even when they have just been generated. What can cause this? The soft-block parameters have not been changed, especially not if you run "generate physical hierarchy" two times in a row.
  2. I use the force descend feature on a certain block. Is there a way to generate the physical hierarchy from the block I descend in?
