  3. How can I use a vpwlf source with design variable for filename...
  • Subscribers 133
  • Views 7340
How can I use a vpwlf source with design variable for filename in AMS simulator (with UNL)?
mad monster
mad monster over 9 years ago
I found the same topic for the spectre simulator:
support.cadence.com/.../cos;solutionNumber=11366978
But actions described there not suitable for "AMS Unified Netlister".
UNL take the cdf simulation information from ams section.
I performed the actions from topic in cdf section for ams simulator, but it did not help.
  • mad monster
    In my irun.log file written (when i use UNL Netlister):
    Error found by spectre during initial setup.
    ERROR (CMI-2011): Unable to open waveform file `cds_globals.pwl_file'.
    No such file or directory.
    'pwl_file' - is the name of the design variable (indicated in vpwlf source) for vpwlf-files.
    `cds_globals.pwl_file' - is the link to the cds_globals.vams file, where stored global signals and design variables (including 'pwl_file').
    I supose, the link incorrectly passed to the netlist.vams file by the netlister.
    In the netlist.vams file written:
    vsource #(.type("pwl"), .file("cds_globals.pwl_file")) V0 (n[3], cds_globals.\gnd! );
    But should be written:
    vsource #(.type("pwl"), .file(cds_globals.pwl_file)) V0 (n[3], cds_globals.\gnd! );
    Here excessive double quotes around the cds_globals.pwl_file.
    Without this double quotes netlist.vams file can be successfully simulated.
    May be one of the netlist procedures of "AMS Unified Netlister" incorrectly pass information from cds_globals.vams file to the netlist.vams file?
    Or May be some error presented in the cdf siminfo for ams simulator?
    When i use OSS netlister (instead of UNL) the same testbench circuit (with the same vpwlf source and the same design variable 'pwl_file') are successfully simulated.
    When i use OSS netlister the tool is successfully locate the pwl_file.
