  3. xmax and xmin are returning nil
  • Views 16703
asetji
asetji over 9 years ago
I am trying to run xmax function on a derived signal, and even though I can see a clear maximum in the plot the xmax(z 1) is returning nil.
The circuit I am using is a simple LC tank driven by a voltage source and I am measuring current and I am using the following outputs
i = ifreq('ac "/V4/PLUS")
z = 1/i
now whether i use xmax(z 1) or xmax(z 0), both return nil which is strange because a maximum does exist. similarly running xmin also returns nil.
My main goal is to find the resonance frequency of the LC tank and then use sensitivity analysis to see how much it is sensitive to individual components.
values of the design variables are
ls=400p, Q=200K, Q_cap=1K, var_cap=100f,w=2*3.14*30e9
    This is because the results from an ac analysis are complex, so there isn't a minimum or maximum value with complex data. Instead you'd need to use a modifier function (such as mag, db20, real, imag, phase etc) to convert the complex numbers at each frequency point to an appropriate scalar value for that frequency point. Probably what you want is xmax(mag(z)).
  • asetji
    ok. got it.
    thanks
