  3. Modification of the Extracted files (Through Cadence tools...
  • Views 15196
Modification of the Extracted files (Through Cadence tools)
samer1
samer1 over 9 years ago
I am working on CMOS 65nm 10Lpe process from IBM. am using cadence 616 and I want to change the resistivity of M1.
The extraction tool is Calibre from MG but the extraction files are encrypted so I am unable to change them.
I was thinking if there is a CADENCE way to resolve that. One thought I had is to change the lumped resistance/cap values in the extracted file in an automated way to account for that. Yet, I am not sure if the extracted file is a cadence of MG file and whether what I am saying is actually doable or not.
Any thoughts or suggestions will be appreciated.
  • Quek
    Quek over 9 years ago
    Hi Sherif
    Even though both Calibre LVS and xRC parasitic extraction are being executed on the Virtuoso platform, the operations are independent of Virtuoso and hence there is no "Cadence" way to resolve your issue. You can try using "PEX Resistance Parameters" command in the deck to see if it helps. If it does not help, it would be best for you to post the same question in Mentor Graphics forum.
    By the way, I think "Calibre" generally refers to DRC/LVS operations. I think it might be better if you use "Calibre xRC" so that the reader knows that you are referring to the parasitic extraction part of the flow and not LVS parameter extraction, etc. The word "extraction" can sometimes be confusing because it can either mean LVS parameter extraction or parasitic extraction.
    Best regards
    Quek
  • samer1
    Thank you so much Quek.
