  3. PhysConfig: Set physical parameters when using force descend...
  • Views 15245
RVERP
RVERP over 9 years ago
Is it possible to set the physical values (lib/cell/view) when you use force descend?
For example, in the physconfig of layout TOP, there is block A1. Block A1 contains blocks AA1 and AA2. I set a force descend on A1, so when I update the component, AA1 and AA2 are generated.
Is it possible to change the lib of AA1 and AA2, while editing the physconfig op TOP?
  • Quek
    Quek over 9 years ago
    Hi RVERP
    Currently it looks like it is not possible to edit the physical parameters during force descend. May we have your help to submit an enhancement request through COS?
    Best regards
    Quek
