  3. Layout Make readonly/Review Request
  • Views 1231
JackPro
JackPro over 9 years ago
 Usually in layout teams there will many users and most of the cases layout cells will be locked by many users. One user need to ask another user "to make read only" by orally, email or chat.
Say, user U2 locked a layout cell. Now user U1 want to edit the same. Now U1 will try to make it edit, and let him send  message to user U2's ICFB.
 Now the question is how to run command in someone's icfb?
I am aware of the fact that, the user U2 is not running icfb then this method fails.
JackPro
  • Quek
    Quek over 9 years ago
    Hi JackPro
    I have not tested this but I think it may work:
    a. In Virtuoso sessions of both U1 and U2, use ipcBeginProcess to do asynchronous communication with a perl script
    b. The perl script should do the following in an endless loop:
    - Sleep 30 seconds
    - Check a file named "edit_request" in the home directory of all users
    - "edit_request" file should contain 2 columns : "requestorID receiverID"
    - Send the info to the paired session of Virtuoso
    c. Request for editing permission can be made using a SKILL script. The SKILL script should do the following:
    - Add "U1 U2" to the "edit_request" file in home directory of U1
    d. The perl script will then send the info to Virtuoso. On the Virtuoso side, the message can be displayed in a dialog box
    Instead of going through the above elaborate and possibly error-proned method, it might be best to purchase a version management software (e.g. designSync, ICmanage, etc) so that such editing requests can be more properly tracked.
    By the way, it would be best if you state the version of Virtuoso clearly. : )
    Best regards
    Quek
