  3. Using alter parameter to set dependent analysis variables...
  • Views 14967
Using alter parameter to set dependent analysis variables on the same ADE-L test bench
Johanny Saenz
Johanny Saenz over 9 years ago
Hi all.
I want to use through GUI interface the alter parameter to set dependent analysis variables on the same ADE-L test bench. This approach would allow the use of the same test bench for different analysis at different variables conditions.
    It's not clear what you're asking here, but it sounds to me as though it's precisely what ADE XL (or ADE Assembler) is intended for.
    There is no "alter" support (especially between analyses) in ADE L.
