  3. ERROR (ADE-3036): Errors encountered during simulation....
  • Views 25090
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
conrel
conrel over 9 years ago
I have just installed IC616, INCISIVE151,MMSIM151, and other tools. but while running a simple inverter transient analysis, i am getting following errors. kindly let me know the possible reasons and the solution.
*INFO* (icLic-25) License Analog_Design_Environment_GXL ("95220") was used to run ADE L.
Loading msgHandler.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
Delete psf data in /home/rajesh/simulation/inv/spectre/schematic/psf.
generate netlist...
Loading seCore.cxt
Begin Incremental Netlisting May 16 20:25:32 2017
WARNING (OSSHNL-145): Incremental netlisting is not possible since the netlist in this run directory
was generated using a previous IHNL version which is incompatible with the
current IHNL version. Therefore re-netlisting the entire design using the
End netlisting May 16 20:25:32 2017
Loading monte.cxt
Netlisting Statistics:
Number of components: 3
Elapsed time: 1.0s (3.00/s)
Errors: 0 Warnings: 0
...successful.
compose simulator input file...
...successful.
start simulator if needed...
...successful.
Loading paraplot.cxt
Possible cause could be an invalid command line option for the version of the simulator
you are running. Choose Setup->Environment and verify that the command line options
specified in the userCmdLineOption field are supported for the simulator.
Alternatively, run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the error.
    Did you try this suggestion? It may well be that something is wrong with the shared libraries or something like that which means that the simulator can't start...
  • conrel
    Thanks Andrew, I have run the spectre standalone and this is showing the following errors
    [rajesh@iitgn netlist]$ csh
    [rajesh@iitgn netlist]$ source ~/cshrc_new_version
    [rajesh@iitgn netlist]$ spectre input.scs
    Fatal error in MPI_Init: Other MPI error, error stack:
    MPIR_Init_thread(420)..............:
    MPID_Init(180).....................: channel initialization failed
    MPIDI_CH3_Init(38).................:
    MPID_nem_init(244).................:
    MPID_nem_tcp_init(108).............:
    MPID_nem_tcp_get_business_card(354):
    MPID_nem_tcp_init(313).............: gethostbyname failed, iitgn (errno 1)
    This article on the support site explains this problem. The issue is that the host name on the machine can't be resolved - you should check that /etc/hosts has the machine name properly defined (the article explains this a bit more).
  • conrel
    Thank you Andrew, issue resolved it was just conflict of hostname . But I have one doubt that how to set virtuoso -64 default? In my case if i am invoking virtuoso by typing $ virtuoso & it tries to open virtuoso 32 bit and ends up with library error, but $ virtuoso -64 working fine.
    So is there any way to setup virtuoso 64 default?
    Yes. If you had been using IC617, then there is no 32-bit virtuoso anymore, but in IC616 you can use:
    setenv CDS_AUTO_64BIT virtuoso
    or
    setenv CDS_AUTO_64BIT ALL
    (of course, use the appropriate means to set the env var for whatever shell you're using). The first means that just virtuoso will be forced to be 64 bit, whereas the second means that all tools will be 64 bit (including spectre and so on).
    Of course, set this before you start virtuoso.
  • conrel
    Perfect! Thank you Andrew.
