  3. ADE: Use of nested design variables in output expressio...
  • Views 18584
ADE: Use of nested design variables in output expressions
sommer
sommer over 9 years ago
I have defined the following design variables: (for sake of clarity I use the OCEAN syntax)
desVar(      "fin" 400M    )
desVar(      "Tin" "(1/VAR(\"fin\"))"    )
desVar(      "simTime" "500*VAR(\"Tin\")"    )
Now I try to plot an eye diagram using:
EYE = eyeDiagram((VT("/Vout+") - VT("/Vout-")) 0 VAR("simTime") ((2 * VAR("Tin"))))
it does not work. I get the following error message:
sevPlotAllOutputs('sevSession13)
*Error* ("eval" 0 t nil ("*Error* eval: not a function" (2 * VAR("Tin"))))
ERROR (ADE-1057): Could not evaluate expression
Expression:'eyeDiagram((VT("/Vout+") - VT("/Vout-")) 0 VAR("simTime") ((2 * VAR("Tin"))))'
because of the following error(s)
Ensure that the definition of the expression is correct.
When I use only the variable "fin" in my expression, the plot succeeds:
EYE_EXPLICIT = eyeDiagram((VT("/Vout+") - VT("/Vout-")) 0 ((500 * 1) / VAR("fin")) ((2 * 1) / VAR("fin")))
Is there a way to use the nested variables in the output expressions?
In my simulation setup for the tran simulation I can use nested variables:
analysis('tran ?stop "1*VAR(\"simTime\")"  )
we work with IC6.1.6-64b.500.8
Best regards
Hans
    Hans,
    This is not because of the nested variable references, but due to the fact that SKILL (which what your expression is) doesn't like duplicate matched parentheses. These confuse the parser where it is trying to determine whether it should use C-like or Lisp-like expressions:
    In this case the problem is around the 2*VAR("Tin") - you have two parentheses before and two after. In fact you don't need either of the two parentheses, but if there was only one it should work:
    eyeDiagram((VT("/Vout+") - VT("/Vout-")) 0 VAR("simTime") (2 * VAR("Tin")))
    Better still:
    eyeDiagram(VT("/Vout+") - VT("/Vout-") 0 VAR("simTime") 2 * VAR("Tin"))
  • sommer
    Hello Andrew,
    thank you for your reply.
    Unfortunately it does not seem to work even without parentheses.
    I have made some trials with the calculator:
    When I enter
    VAR("fin")
    it prints correctly 400M
    but with
    VAR("Tin")
    it prints the error in CIW:
    expression evaluation failed: Expression evaluates to nil
    expression evaluation failed: VAR("Tin")
    Best regards,
    Hans
    Hans,
    Can you contact customer support? I think we'll need to see your data to better understand what's going on - whether it's a mistake, or a bug.
