  3. Marking nets in cadence showing shorts
  • Replies 12
  • Views 22098
anandmohan
anandmohan over 9 years ago
HI ,
When I am trying to mark nets in cadence to verify routing i am am seeing shorts. Cadence version is IC6.1.7-64b-500.7 . Marking the nets is also highlighting other unconnected nets, but LVS is going clean so there is no physical connection b/w them. Is there any way to solve this issue or any work around.
Regards
Anand Mohan
  • anandmohan
    Hi Marc,
    If I enable only single metal at a time it is working. But my requirement is to obtain a power plot of supply nets, which need all the metal to be enabled. Thanks you for your time
    Regards
    Anand
  • anandmohan
    anandmohan over 8 years ago
    HI,
    Mark net issue in layout can be solved by adding the line
    envSetVal ("layout" "useMarkNetWithNewChaser" 'boolean nil)
    invoke this command in the CIW window.
    (posting this solution so that someone may find it helpful)
    Regards
    Anand Mohan
