  3. Only part of transient time displayed.
  • Views 14601
syafiq
syafiq over 9 years ago
I have a similar transient time displayed issue as reported in  https://community.cadence.com/cadence_technology_forums/f/38/t/22201
From spectre.out, the simulation is completed successfully at 1s. However, in the graph window only shows up to 200ms.
Andrew has given a suggestion in the previous discussion (see the link above) of how to solve this problem which requires rerunning the simulation.  May I know is there any workaround without having to rerun the simulation? My simulation took > 12 hours to complete.
Cadence version: IC6.1.4
Spectre version: 7.1.1.187.isr11 64bit
Syafiq
  • syafiq
    It seems that after I restarted the cadence, it solved the issue.
    I am not sure what is going on now.
