  3. Exporting ADE-L Variables
  • Views 16565
netbug
netbug over 9 years ago
Dear all,
I have an ADE-L session which has some variables defined and I would like to export them so they could be used in a script (tcl script). Is there a simple way of  doing it ?
Best regards,
José
PS: Not sure if this is the right forum to ask this....
    José,
    The design variables for the current session can be found using:
    asiGetDesignVarList(asiGetCurrentSession())
    With that you could write something to export them to wherever you want.
  • netbug
    Thanks for your answer.
    So, without writing a skill script, how can I export the variable in Cadence so it can be used by a TCL script ?
    My application:
    I have an ADE-L session which calls a tcl script and opens SimVision. That script will run a piece of code everytime SimVision starts. As this may not be what all the users want, I would like to have a variable built in to ADE-L which could allow the script being run automatically or not.
    Many thanks.
    Best regards,
    José
    You can't. Not sure why you would expect to be able to export an ADE variable to a Tcl script - this seems very specific to your particular needs - and precisely the kind of thing that SKILL is there for!
  • netbug
    I've solved it, but maybe in a way that is not the most correct.
    From the cds_globals, using the describe command, I could get the value for the ADE-L variable, an then use it.
    set aVar [describe cds_globals.AUTORUN]
    set aList [split $aVar "="]
    set ade_l_var [lindex $aList 1]
    if {$ade_l_var==1} {
    # If AUTORUN was set to 1 run tcl script
    source myFile.tcl
    mainFunction
    } else {
    # If any other character other than 1 do nothing
    Best regards,
    Pedro
    Hi Pedro,
    OK, you didn't mention that you were using AMS Designer as the simulator. That's rather important information!
    You could do it even more simply - use:
    value cds_globals.AUTORUN
    No need to parse the output of the describe command then; the value command directly returns the value of the variable AUTORUN within the cds_globals module.
  • netbug
    Thanks you for your help.
    Yes, I didn't mention the simulator ... sorry
    Best regards,
    Pedro
