  3. Export simulation results from Virtuoso 6.1.6
  • Views 15664
bitan1990
bitan1990 over 9 years ago
I am a newbie in Virtuoso. I have bulk of simulation data which I want to export from Analysis. Individual file handling is too much time consuming. Is there any work around?!
I do not have Virtuoso locally available at my PC. I am running Virtuoso via university server.
P.S. I know there are techniques like .ocn scripts or file handling with veriloga modules, but I am not sure which one is simple and fast. Kindly give your input!
EDIT : I am using Cadence version IC6.1.6.500.1, Simulator Spectre. I want to export simple result : for example Id and Vg from a dc sweep of NMOS. Typically if I could get the data from the Visualization and Analysis XL Table into my local PC in .dat format that will work.
    You'll have to be a bit more specific than that, I'm afraid. Export what "simulation data"? Where are you hoping to export it to? What Virtuoso tool are you using, which simulator, and which version of the IC tools and simulator?
    Your question was far too open - which would make answering it very hard - I could guess at what you might mean, and explain at great length something that is totally irrelevant! That's why the forum guidelines ask you to be precise...
  • bitan1990
    I have no idea what ".dat" format is...
