  3. RE: ADEXL parametric simulation scalar plot
  • Views 16091
kenambo
kenambo over 9 years ago
Hi All,
         I am using IC6.1.6 version of virtuoso. I want to do a parametric analysis for a scalar value versus temperature. I can do it easily for one corner in ADEL that the scalar varialbe is plotted with respect to my sweeping variable(temperature).But in ADE XL I can run parametric anlaysis but it simulates as individual simulations and I couldn't get the scalar variable plot vs sweeping variable.
I have read some old posts where this facility will be available for IC 6.1.6. So is this option available with 6.1.6? and Is there any other way that I can do parametric analysis across corners like SKILL or Ocean?  If anything please share..
Thanks.
  • Marc Heise
    Marc Heise over 9 years ago
    Did you try to right click the scalar value in the output pane and select "Plot across Sweep"/"Plot across Corner" ? (Can be named differently don't have an open session in front of me at the moment)
  • kenambo
    Thanks  I got it.
