  3. Physical verification system menu is not working proper...
  • Views 17337
Physical verification system menu is not working properly
anandmohan
anandmohan over 9 years ago
HI All,
Recently physical verification system tool is installed and integrated to virtuoso but the menu options are not working. when i am trying to use any option i am getting the following error
   _pvsOpenIPVSrunform( 'erc ?timeout 30)'
  _pvsOpenIPVSrunform( 'drc ?timeout 30)'
PVS Version: PVS 15.22-s262-64b
Virtuoso: IC6.1.7-64b.500.7
these are the versions of tools i am using.  Can anyone tell me how to solve this?
Regards
Anand
    Anand,
    That doesn't look like an error - just the SKILL functions used to invoke the form (which would appear if Options->Log Filter has the "\a Accelerated input (menu and bindkey commands, form and field value settings ..." checked)
    So was there another error message? What symptoms are you seeing?
  • anandmohan
    HI Andrew,
    The issue I am facing is, none of the options under the 'PVS' menu is opening when I click on them. ie I am not seeing any pop up window for any of the options in PVS menu.
    Also I am seeing this warning messsage in CIW window: Warning PVS licenses existence check is not complete - all menu items are shown
    (Also is there any way to invoke PVS standalone, ie not through virtuoso window. as a work around)
    Regards
    Anand
    Anand,
    There's a bit of guidance in this article on Cadence Online Support. Perhaps you have $OA_HOME set? If so, please don't set this (make sure it is unset (if using ksh/sh) or unsetenv'd (if using csh) before starting virtuoso).
  • Marben
    Marben over 8 years ago
    Hi Anand,
    Try installing "libXp.x86_64" in your machine.
    Best regards,
    Marben
