  3. Convergence difficulties in Verilog A while using equivalent...
  • Views 17451
Convergence difficulties in Verilog A while using equivalent differential equation instead of laplace_nd function
Quilon
Quilon over 9 years ago
Hi
I was using a laplace_nd function to realize a CTLE block as follows
V(vp) <+ laplace_nd((0.5*(V(INP)- V(INN)))*rl*gmn , hn , hd);
V(vn) <+ laplace_nd((0.5*(V(INN)- V(INP)))*rl*gmn , hn , hd);
whre hn, hd are declared as "real hn[0:2], hd[0:3];"
It worked well without any sort of convergence difficulties in bot AC and transient simulations. But since I wanted to change the values of hn and hd in between the transient simulation, I changed the laplace_nd function into equivalent differential equation as given below
V(vp) <+ ((0.5*gmn*rl*(hn[0]*V(vip)+hn[1]*V(vipd)+hn[2]*V(vipdd)))-hd[1]*V(vpd)-hd[2]*V(vpdd)-hd[3]*V(vpddd))*(1/hd[0]);
V(vn) <+ ((0.5*gmn*rl*(hn[0]*V(vin)+hn[1]*V(vind)+hn[2]*V(vindd)))-hd[1]*V(vnd)-hd[2]*V(vndd)-hd[3]*V(vnddd))*(1/hd[0]);
where
V(vip) <+ V(INP)- V(INN);
V(vin) <+ V(INN)- V(INP);
V(vipd) <+ ddt(V(vip));
V(vipdd) <+ ddt(V(vipd));
V(vind) <+ ddt(V(vin));
V(vindd) <+ ddt(V(vind));
V(vpd) <+ ddt(V(vp));
V(vpdd) <+ ddt(V(vpd));
V(vpddd) <+ ddt(V(vpdd));
V(vnd) <+ ddt(V(vn));
V(vndd) <+ ddt(V(vnd));
V(vnddd) <+ ddt(V(vndd));
The modified model showed exactly same AC response without any convergence difficulties. But it is showing convergence difficulties in transient simulations of same conditions (blowup parameter of nature Voltage was increased to accommodate high values coming to third derivative terms in the differential equation). How can I make the differential equation as convergable as the laplace_nd function.
Thanks and Regards
Quilon
    Quilon,
    You probably need to either scale the higher derivatives or better still define new natures and disciplines for them which have got different abstols and blowup values to avoid this problem. Since the higher derivatives aren't really voltages any more, this would give the simulator a chance...
    For ideas on how disciplines and natures are defined, take a look at: <SPECTREinstDir>/tools.lnx86/spectre/etc/ahdl/disciplines.vams
  • Quilon
    As per your suggestion I defined a new discipline and nature for all the derivative terms. But unfortunately it is showing the same problem of " No convergence achieved with the minimum time step specified." .  The simulation log file is not having any extra warning which was not there in the "laplace_nd" case as well.
    Thanks and Regards
    Quilon
    Quilon,
    Please contact customer support. I don't think it's really going tone possible to help without seeing the model and test bench that causes the problem. Then we can see if it's really a blowup error - or what the root cause is.
