  3. Stop view
  • Views 19537
Stop view
samer1
samer1 over 9 years ago
I am confused about the concept of the stop view. Let's say I have a a two terminal device "X" that I implemented in verilogA and have some parameter in it. Once I save it as a symbol, those parameters are automatically added to the CDF list. Now let us say that I added a spectre view of the device, and added those parameters to the CDF list in the by simulation tab, how would that affect the simulation of that device?
Can someone give me an example that illustrates that concept?
    Probably a bit of a late reply, but the principles of switch view lists and stop lists are quite simple. The idea is that when the hierarchy is being traversed by the netlister, when it comes to an instance it will look along the view list in order and see if one of those views exists. Once a view is found it switches into that view. If the view that is switched into is in the stop list, no further hierarchical expansion is performed and netlisting is done using the simulation information in the CDF for that component (with a slight complication I'll mention in a moment). If it's not a stopping view, that view is then traversed and netlisted as a subckt (or similar depending on the netlister).
    The complication is that there's something called view-specific CDF which is where things like the veriloga analyser add some additional information in the CDF about a specific view. This is to allow (for example) multiple veriloga views with different terminal orders or different parameters.
    Anyway, if you add a spectre view then usually that is before veriloga in the switch view list, and hence it will stop expanding the hierarchy and netlist the component using the simulation information in the CDF. It will however not add the ahdl_include in the netlist because it is unaware of the veriloga view being used.
    Hopefully that helps!
