  3. Is there any way to use assura compatible file (*.drc ,...
  • Views 15674
Is there any way to use assura compatible file (*.drc , *.lvs ) file in PVS plugin (*.pvl)
Anklon
Anklon over 9 years ago
My Cadence have PVS plugin and my technology library (tsmc) contains assura_tech file. Is there any way to convert those file in PVS compatible format or any other way to use those in PVS plugin ?
thank you
    First of all you should check with TSMC whether there are PVS decks available for the technology you're using. If not, there's no reason why you can't just use Assura - you can run Assura even if  you only have PVS licenses.
    There's no conversion route - it doesn't make a lot of sense to do that when you can use the tool intended for the original rule deck.
