  3. Title Block Properties Moving
  • Views 15410
AJ Pyne
AJ Pyne over 9 years ago
I've created custom title blocks with custom properties. I have selected the justification, font, size, etc. for where they are located on the title block, and have placed them appropriately. These title blocks are in their own library, saved with unique names.
I place the title blocks, and populate them with the Edit>Browse>Title Blocks/Edit>Properties, or by double-clicking the default value on the page in question.
The properties move around without any perceivable pattern. They will hang off the edge of the page, move around inside or outside the title block, put themselves on top of each other, etc. I have to manually drag them back ON EACH PAGE, ONE AT A TIME to where they belong when I generate PDFs, then they will move again after anything changes (save/open close/update/change properties/change sheet size etc.).
I have tried replacing/updating the title blocks/cache both preserving or replacing the part properties. I've tried combinations of deleting them/clearing design cache/saving title blocks differently, etc. No luck.
What am I missing?
AJ
    AJ,
    I can't see how or why this would happen (unless you just got the justification wrong). They should be interpreted labels and so should appear wherever they were in the master cellView.
    Best thing would be if you contact customer support so we can take a look at what you've done.
