  3. vbit source in analogLib
  • Views 16985
Windsor1
Windsor1 over 9 years ago
I tried using the vbit source from analogLib in cadence virtuoso 5.1.0 04/26/2009. I would like to simulate my design  with a specific bit pattern. but it gives me error. please see attached snapshot for the error .
    My guess is that you're using spectreS rather than spectre as the simulator interface. That has been obsolete since IC443 when the new "spectre" interface was introduced. Given that IC443 came out about 18 years ago, there really is no good reason to use it even in an 8 year old build of 5141 (which itself came out 13 years ago). So why are you using it (if you are)?
    If you are using spectre (not spectreS) as Setup->Simulator in ADE, then the switch list is incorrect (check Setup->Environment and change the stop list to have "spectre" rather than "spectreS"). Note, if  you are using spectreS as the simulator, then just fixing the switch list won't be enough.
  • Windsor1
    Thank you Andrew. Change to spectre and it's working.
    Best regards
