  3. Basics about wire labels and general text
  • Views 16769
ARWAH HAWRA
ARWAH HAWRA over 9 years ago
hi
1) Can a wire be defined with two wire names with some dummy element between them. (actually during my simulation tests i have to bypass the switch to check the o/p therefore one name either at input or output need to be deleted.)
2) how can i enter the text in cadence schematic window (for some reference to remember about schematic purpose). I found text written in some example schematics of cadence.
thanks
    Answers:
    1. It's not entirely clear what your objective is here - what is the purpose of this "dummy element"? Why do you need two names? It sort of sounds as if you want to use basic/cds_thru/symbol which effectively is a short (you might be able to use basic/patch if it's an internal net, but it's not clear what you are trying to do).
    2. Create->Note->Text
  • ARWAH HAWRA
    actually i made a transmission line schematic. I am looking at input and output. For some testing purpose; i have to eliminate the inductor in between two lines; in that case the input and output labels are on same net which is not allowed. Therefore i was in search of some element that could eliminate this issue. cds_thru worked and also note issue solved. Thank you very much
