  3. Problem of RC Extraction with GPDK45nm(gpdk045_V_3_5)
  • Views 1854
JB786
JB786 over 9 years ago
Hi
When I was running RCX extraction using ASSURA with gpdk045 model. Always I'm getting warnings and then failed to extract layout. From the log file, some libraries models are missing in gpdk45.
Please see below log file.
Thank you
  Assura (R) Physical Verification Version av4.1
Copyright (c) Cadence Design Systems. All rights reserved.
assura version av4.1
Loading tech rule set file : /root/gpdk045_v_3_5/assura/techRuleSets
Checking out 1 license for Assura_RCX
Starting /mnt/cadence/ASSURA41_USR3_HF1_615_lnx86/tools/assura/bin/rcxToDfII /root/gpdk045_v_3_5/rcx.SRAM_cell_layout.rsf -t -cdslib /root/gpdk045_v_3_5/cds.lib -libdefs /root/gpdk045_v_3_5/lib.defs
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
*WARNING* lib.defs files and the -libdefs option are no longer supported. The file '/root/gpdk045_v_3_5/lib.defs' will be ignored. The cds.lib file '/root/gpdk045_v_3_5/cds.lib' takes precedence.
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.5:IC6.1.5.500.15 02/20/2013 00:18 (sfrh54) $
sub-version 4.1_USR3_HF1, integ signature 2013-02-19-2240
run on localhost.localdomain from /mnt/cadence/ASSURA41_USR3_HF1_615_lnx86/tools.lnx86/assura/bin/32bit/rcxToDfII on Tue Jul 25 21:48:38 2017
Loading gpdk045/libInit.il ...
     Loading gpdk045/loadCxt.ile ... done!
     Loading context 'gpdk045' from library 'gpdk045' ... done!
     Loading context 'pdkUtils' from library 'gpdk045' ... done!
     Loading gpdk045/gpdk045_customFilter.il ... done!
     Loading gpdk045/libInitCustomExit.il ...
     Loading Environment Settings ...
     Loading gpdk045/gpdk045_PDKRegistrations.il ... done!
  *              Cadence Design Systems, Inc.                 *
  *                    Generic 45nm PDK                       *
  *                        (gpdk045)                          *
     VERSION: 3.5
done!
Loaded gpdk045/libInit.il successfully!
*WARNING* No library model for device "g45inda".
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (g45cmim ivpcell) from lib (gpdk045) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
*WARNING* No library model for device "g45cmim ivpcell gpdk045".
*WARNING* No library model for device "g45inds".
Finished /mnt/cadence/ASSURA41_USR3_HF1_615_lnx86/tools/assura/bin/rcxToDfII
Starting /mnt/cadence/ASSURA41_USR3_HF1_615_lnx86/tools/assura/bin/avRCXxref /root/gpdk045_v_3_5/rcx.SRAM_cell_layout.rsf
@(#)$CDS: avRCXxref version av4.1:Production:dfII6.1.5:IC6.1.5.500.15 02/20/2013 00:13 (sfrh54) $
run on localhost.localdomain at Tue Jul 25 21:48:39 2017
Reading rsf
Finished /mnt/cadence/ASSURA41_USR3_HF1_615_lnx86/tools/assura/bin/avRCXxref
Constructing the RCX run script
*WARNING* at "RCXspice": ?extractMosDiffusionAP option will be retired in the next release.
Could not open file /root/gpdk045_v_3_5/assura/../qrc/RCXspiceINIT for reading
*WARNING* Bad return status from RCX script generator. 0x100
    Two things:
    1. You should use Quantus QRC not Assura RCX (QRC is in the EXT stream). Assura RCX is very old and no longer maintained
    2. The missing ivpcell for g45cmim was fixed in gpdk045 version 4.0 (you're using 3.5). You should be able to workaround this by unchecking the "Enable cellview check" checkbox on the QRC form (or Assura RCX form) - this will not then complain if any of the devices seem to be missing.
