  3. VerilogA issues -- transition function
  • Replies 10
  • Views 13102
funfet
funfet over 9 years ago
I'm creating a verilogA model for a circuit component and wish to have smoothly transitioning variables. The variables are of the real data type and I can't seem to use the transition function on them without the simulation returning an error. Is there some equivalent of the transition function that I can use on real data types just like I can use for currents (e.g.). Above I have pictures showing the variables that I wish to smooth out. I'm trying to eliminate the flat plateaus where the variables are constant.
Thank you
Paul
    You either want to use something like the slew function (rather than transition, which is intended for discrete values), or use some kind of smoothing function, such as something tanh-based. A bit of googling found this - there almost certainly are more realistic examples out there with a bit more searching.
  • funfet
    Thank you for your reply. Is that the correct link? It takes me to designers (dot) org but no specific thread.
    Whoops! I took the  link from the user account rather than the post. My apologies. The correct link is here.
  • funfet
    This may be hard to explain but I will try my best. The code which generated the output is actually generated from a csv file. depending on the input voltage across the two port device the code will sum a different amount of real numbers in the csv file so that the variables take on a discrete value. In such a case would it be okay to use the transition function?
    You can use transition on values with discrete steps - that's a reasonable use model (one might use it on a sample and hold output for example). However, you were asking about eliminating the plateaus in the output in the graphs you plotted - that won't happen if you use transition - so it's unclear what you actually want here...
  • funfet
    Yes. you're right, I don't think the transition function would work for what I'm trying to do. This is the first model I'm developing in VerilogA and I'm still quite a novice.
    Would it be possible to increase the time step size which cadence uses to calculate the two variables? So that it wouldn't evaluate the variables at no less than some minimum time apart? So if I wanted it to evaluate the variables at most every .2 seconds for instance it would evaluate the variable for transient times that are > .2 seconds apart but not < .2 seconds apart? I was trying to use the timer function for this but I'm not sure if this is the right approach.
    When you are talking about the time step size which "cadence" uses to calculate the two variables - I've no idea what you are referring to. Which two variables? You've not posted your model so we're all rather in the dark here as to what your code is actually doing or what you want it to do...
  • funfet
    My code is below. I was hesitant to post it because it's such a niche application but the model is for a ferroelectric capacitor. The model has weird current spikes at times however and also fails to converge at times, which is what I'm trying to fix. The spikes in my opinion occur when polarization_next and polarization_prev have the same value on and off for some time span (those are the curves I posted initially) and I was wondering if it would be possible to impose a condition such that the polarization_next and polarization_prev variable would not be evaluated at such frequent time intervals. Perhaps this would get rid of the plateaus but I don't know whether this is possible in VerilogA. I was experimenting with the timer function for this purpose.
    I'm wondering if the following line of code is wrong which is what I'm investigating right now. Unfortunately it's difficult to work with 1D arrays in verilogA with something that should be a 2D array....
    domain_states[j] = 1;
    I will get back to you with the above line if I find that it's wrong.
    There are some papers on the topic like "Preisach model for the simulation of ferroelectric capacitors" by Bartic and " Preisach Polarization - Electric Field Hysteresis model with iteration method" by Hideyuki Ikeda.
    Basically the model calculates the polarization (also the name of the variable) for an applied voltage V(p,n). The current is proportional to the time derivative of the polarization. I drew a sketch that hopefully helps but I'm not sure how much it will help without reading any of the papers. The polarization is calculated by multiplying each element in the domain_states array by each corresponding element in the preisach_density array and summing the results.
    Thank you for any help.
    ##################################################################### code starts here ###########################################
    This file implements the extraction of csv data into a verilog variable and then implements a Preisach implemenatation of a FE capacitor SPICE
    model based on the Preisach data.
    `include "constants.vams"
    `include "disciplines.vams"
    module test_func(p,n);
        inout p,n;
        electrical p,n;
        //files for reading/writing
        integer mcd, fp;
        real data, v_present, v_step;
        real preisach_density[0:1024];// all elements should add up to 1
        real domain_states[0:1024];// all elements should be -1 or +1 (depending on polarity)
        real polarization;//polarization (between -Pr and +Pr)
        real polarization_prev, polarization_next;
        real time_prev, time_next;
        real v_prev, v_next;
        integer row_offset, column_offset;
        real current_calc;
        integer i, j, k;//used in loops
        integer rows, columns;//describes area scanned from applied voltage
        integer rows_total, columns_total;//gives number of rows and columns in the grid ("rows" and "columns" should not exceed these values)
        analog begin
            @(initial_step) begin
                //read data from csv file and transfer it to verilog-A array variable
                //data stored in csv file should be preisach distribution
                //csv file should have the same number of elements as arrays "preisach_density" and "domain_states"
                mcd=$fopen("whole_preisach_dist_5_1_2017.csv","r");
                while (!$feof(mcd)) begin
                    $fscanf(mcd,"%f", preisach_density[i]);
                    domain_states[i] = 0;
                    i = i+1;
                      end
            v_step = 0.1; // resolution
            rows_total = 3.2/v_step;//the maximum anticipated applied input voltage swing divided by the resolution of the grid cells
            columns_total = 3.2/v_step;//the maximum anticipated applied input voltage swing divided by the resolution of the grid cells
            v_next = V(p,n);
            time_prev = 0;
            time_next = 0;
            // centers the indiciess to the beginning of the fourth quadrant of the Preisach distribution (i.e. half of row_total or columns total plus 1)
            row_offset = 17;
            column_offset = 17;
            end
            if (v_next < v_prev) begin // negative voltage derivative
                rows = row_offset + V(p,n)/(-v_step);
                begin
                if(rows > rows_total)
                    rows = rows_total;
                else if(rows < 0)
                    rows = 0;
                end
                //for all columns
                for(j = 0; j < columns_total; j=j+1) begin
                    //for all rows with a smaller value than "rows"
                    for(k=0; k<rows; k=k+1) begin
                        domain_states[k*columns_total + j] = -1;
                    end
                end
            end
            if (v_next > v_prev) begin // positive voltage derivative
                columns = column_offset + V(p,n)/(v_step);
                begin
                if(columns > columns_total)
                    columns = columns_total;
                else if(columns < 0)
                    columns = 0;
                end
                //value compared to j should equal number of columns in array
                for (j=0; j<columns * rows_total ; j=j+1) begin
                end
            end
                //calculate the present polarization across the device
                polarization = 0;
                for (i=0; i<columns_total*rows_total; i = i+1) begin
                    polarization = polarization + preisach_density[i]*domain_states[i];
                end
                //used for calculating derivatives
                polarization_prev = polarization_next;
                polarization_next = polarization;
                v_prev = v_next;
                v_next = V(p,n);
                time_prev = time_next;
                time_next = $abstime;
                begin
                    if (time_next == 0)
                        current_calc = 0;
                    else
                        current_calc = (polarization_next - polarization_prev)/(time_next - time_prev)*0.000000001;//0.000000001 is arbitrary
                end
            I(p,n) <+ current_calc;
        end
    endmodule
  • funfet
    I found some bugs in the code above. This is the revised code.
    I think sometimes the derivates do not evaluate correctly, specifically:
    (polarization_next-polarization_prev)/(time_next-time_prev)
    I was hoping that there would be a bit of a lag between the polarization_next and polarization_prev when the polarization variable is changing but sometimes they are equal. Is there a better way to take a derivative? I was trying to use the ddt function but I think it only works for voltages and currents, not variables. I think part of the problem may be that the variables are updated too often and so sometimes can evaluate to the same value when the incremental change in transient time is small enough even though the polarization may be changing but not quickly enough to register a change.
    For transient simulations for example the polarization_next and polarization prev variables may evaluate to be the same for times 1 s and 1.001 s but may be different at 1 s and 1.1 s. Is there a way to force verilogA to limit how often it evaluate the variables (i.e. limit the minimum resolution of the time step of the transient time)?
    #################### revised code ######################################
    inout p,n;
    electrical p,n;
    integer mcd, fp;
    real current_calc;
    analog begin
    i = i+1;
    end
    v_next = V(p,n);
    time_prev = 0;
    time_next = 0;
    row_offset = 17;
    column_offset = 17;
    end
    begin
    rows = rows_total;
    else if(rows < 0)
    rows = 0;
    end
    //for all columns
    end
    end
    end
    begin
    columns = 0;
    end
    for (j=0; j<columns; j=j+1) begin
    for(k=0; k < rows_total; k=k+1) begin
    domain_states[k*columns_total + j] = 1;
    end
    end
    end
    polarization = 0;
    end
    v_prev = v_next;
    v_next = V(p,n);
    begin
    if (time_next == 0)
    current_calc = 0;
    else
    end
    end
    endmodule
  • funfet
    funfet over 8 years ago
    Andrew, It seems like I got my code for the time being. Thank you for your help.
