  3. Verilog-A model equivalent to primitive model?
  • Views 17507
greatqs
greatqs over 8 years ago
I'm build a AMS test bench (ADE based) and try to replace all resistor/inductor/capacitor from analogLib primitives to Verilog-AMS models.
The purpose is to make every elements flexible to be changed in the AMS stimulus sequence by OOMR without too many ADE variables.
An example of inductor is as below (similar for resistor and capacitor), my question is this model ( I and V linked by ddt() or idt()) accuracy is the same as Spectre primitives in AMS simulation?
If not, how can I improve the accuracy to make sure my simulation results will be the exactly the same as those components in Spectre primitives?
`include "constants.vams"
`include "disciplines.vams"
module ams_inductor(MINUS, PLUS);
inout MINUS;
inout PLUS;
electrical MINUS;
electrical PLUS;
// Default DC inductance
parameter real inductance = 1e-9;
parameter real tt = 10e-6;
// Variables for OOMR
real indSet = inductance;
real ttSet = tt;
analog begin
V(PLUS, MINUS) <+ indSet*ddt(I(PLUS, MINUS));
end
endmodule
  • greatqs
    Hi Is anyone can help on my questions? Is there any tricks regarding on idt() and ddt() on modeling accuracy? For example, I can either use idt() or ddt() in building an capacitor or inductor model, does that cause discrepancy as compared to analogLib primitives on Spectre or IRUN-Spectre?
    Why do you think you need to do something special for accuracy? The accuracy criteria is the same regardless of whether you're using the built-in primitives or implementing yourself using idt/ddt in Verilog-A.
  • greatqs
    Andrew,
    Thank you for your comment. I actually don't expect any accuracy differences. But as I will heavily use this behavior models to replace primitives and just would like to confirm whether any tricks on simulator convergence/speed/accuracy beyond my knowledge would cause headaches for me if to do so.
