  3. layout-xl schematic numbering update
  • Views 14850
NoelCFC
NoelCFC over 8 years ago
I have a layout that is LVS clean with respect to its schematic but, since the last LVS check, all the instances in the schematic has been renumbered. How can I update a layout connectivity (I'm using ic6.7.13 and layout-xl, btw)?
thanks in advance.
    In the Layout window (when you're in VLS XL), do Update->Components and Nets and then on the "Update Nets and Instance Name Mismatches only" checkbox on the Update tab, and then hit OK.
    Note that the names don't have to match for VLS XL to be OK - but if you want them to match, this should do it.
  • NoelCFC
    thanks, Andrew. It worked perfectly.
